Can EGR & Cold start ejector be deleted from an 85 chip?
Old 02-18-2003, 04:44 AM
LD85
LD85's Avatar
Default Can EGR & Cold start ejector be deleted from an 85 chip?
I am bulidng a new motor and will likely upgrade my ECM to the 86-89 ecm, but I would like to get my new 406 motor in and running before I take on the pinout and ecm swap.
Can I have a temporary chip made to eliminate the EGR and Cold Start injector?
The new motor will have a MINIRAM intake and 2151 Hooker headers.
TIA!
Old 02-18-2003, 08:14 AM
HighHopes85
HighHopes85's Avatar
Default Re: Can EGR & Cold start ejector be deleted from an 85 chip? (ld85)
To disable EGR, set EGR flag = false and minimum MAT to enable EGR = the highest reading possible - 1.
CSV is a matter of disconnecting the thermal switch in the front of the engine. CSV is not controlled by the ECM. If you disconnect it, there will be a fair amount of tinkering with the startup enrichment I would assume, assuming you are at a low enough operating temp that CSV would be used in the first place. Good Luck, -Matt
Old 02-18-2003, 01:52 PM
LD85
LD85's Avatar
Default Re: Can EGR & Cold start ejector be deleted from an 85 chip? (HighHopes85)
QUOTE: CSV is a matter of disconnecting the thermal switch in the front of the engine. CSV is not controlled by the ECM. If you disconnect it, there will be a fair amount of tinkering with the startup enrichment I would assume, assuming you are at a low enough operating temp that CSV would be used in the first place. Good Luck, -Matt[/QUOTE]
Once I go to the the 165 ECM how does it deal with the CSV issues since it does not have one?
Old 02-18-2003, 02:24 PM
HighHopes85
You use a PROM with a BIN (program) loaded on it from an '89. In 1989, they ditched the CSV but still used the '165. :cheers:
Old 02-24-2003, 12:06 PM
LD85
LD85's Avatar
So the new BIN will adjust the fuel enrichment afetr the new ECM is in!?
Old 02-24-2003, 12:18 PM
HighHopes85
Correct. Your computer can run any of the PROMs from 1986-1989. Using the 1989 one will give you the enrichment during starting w/o the need for a CSV.
Old 02-24-2003, 03:42 PM
scorp508
scorp508's Avatar
This feature has been introduced into the $32b 87/88 code thanks to Tunercat. So you can use that one too. Much more handy if you have a 4+3 so you do not lose O/D features.
Old 02-28-2003, 03:04 PM
LD85
LD85's Avatar
Default Re: (scorp508)
Great I do have the 4+3 so this is very helpful!
Old 03-05-2003, 11:06 AM
CMYC4GO
CMYC4GO's Avatar
Default Re: (ld85)
So let me get this straight...I can put an EProm in my 85 from an 89 and it will still work without too much effort? Weren't emissions standards different in 86-7-8-9?
Old 03-06-2003, 03:37 AM
ol,RJ
ol,RJ's Avatar
Default Re: (Klimper)
no, the 85 has a different ECM.
ID85 is talking about after he changes his ECM to a 165 unit (used in 86 thru 89). the ECM swap takes some wiring changes (there are some home pages out there on this swap).
To Can EGR & Cold start ejector be deleted from an 85 chip?
Quick Reply: Can EGR & Cold start ejector be deleted from an 85 chip?
