How do you tell the difference between a 4L60 and 4L60E?
Re: How do you tell the difference between a 4L60 and 4L60E? (Vette92)
I believe the 4L60E started in 94.
Transmission evolution is something like this:
1991 - TH700 renamed 4L60 in 91
1994 - added electronic control to become the 4L60E in 94.
All the same transmission, however.
Cruise-In II Veteran
The 700R4s and the 4L60s have a TV cable, while the 4L60E is electronicaly controlled. :steering:
Received 1,400 Likes
Re: How do you tell the difference between a 4L60 and 4L60E? (edsalinas)
No TV cable, the computer runs it.
Whether its the best or not is debatable, id rather have a 4L80.
1 Post
St. Jude Contributor
Re: How do you tell the difference between a 4L60 and 4L60E? (vader86)
Problem I had was it was so expensive ! ! ! !
[Modified by edsalinas, 2:55 PM 3/18/2003]
I've got a 94 with the 4L60E. One day at an open track event I blew it up. Lost third gear totally, 2nd gear slipping bad. I blew about two Qts of tranny fluid out the dip stick tube( I bet that's what smoked the gears)! It was smoking like a mosquito bug spraying truck! I had so much smoke inside the car I could not even see all the black flags waving at me! :lol:
Since then I only use Mobil 1 synthetic fluid, I've had extra clutches installed with Kevlar bands, out board Trans cooler and a B&M shift kit. I've been beating it hard with drag racing, autox's & high speed track events for a few years now with no sign of wear. I just change the fluid after a hard day of playing.
I have heard that the 4L60E was introduced during the '93 production run.
OK, so I have three cables going into the ASR. Is the extra one of those the TV cable? If so, then I have the 4L60.
boostedevoviii (04-19-2022)
Re: How do you tell the difference between a 4L60 and 4L60E? (cprgmr)
I guess I should have said 4 cables instead of 3.
Thanks a ton for the pics. That proves that we have a 4L60 and not a 4L60E in the '93. :cheers: :cool: :thumbs: :steering: :auto:
Elite Torch Red Member
Chris, the 4L60 would have the black ECM and the 4L60E would have the silver PCM with the fins on it. Although I've yet to see a '93 with the 4L60E.
BTW, that's a nice clean engine compartment. Did you take the pictures on the showroom floor?
:cheers:
:cheers:
Well, now I'm really confused. I have a late 93 and the codes in the center console say that it has a 4L60E. But according to your pictures, it is not. What makes it more confusing is that after having a custom chip installed, all my shift points changed (for the better). Wouldn't the transmission have to be electronically controlled for a chip to change the shift points? Excuse me, but I'm kind of an idiot on this subject. Does it say somewhere on the transmission which model it is? Thanks
Re: How do you tell the difference between a 4L60 and 4L60E? (John Row)
Thanks John - the pics were taken in my driveway (the 4L60E was taken from a fellow forum member)! :)
Re: How do you tell the difference between a 4L60 and 4L60E? (Lichen)
1998, 2005, 4l60, 4l60e, 4l80, 700r4, 84, 93, corvette, differances, difference, differences, diffrence, transmission, tucson
