How much would a LT4 hot cam kit for a LT1 run about??
If I get one what else should I consider doing? See sig for current mods.
Re: How much would a LT4 hot cam kit for a LT1 run about?? (Crispyc21)
Call Jeff Kopp at Superior Chevy. 1-800-728-8267 for a real good price and excellent service.
Most will say to swap out the hotcam springs for some better ones from like comp cams or others because the HC springs are a little weak. I don't know if that is true or not. I have never read anything one way or the other to date, but that doesn't mean it doesn't happen. Who knows because there are far too many variables involved.
Jeff can get you all the gaskets and such that will be needed as well. Shouldn't need to change anything else really. Would be a good time to install new valve seals though.
A minor reprogram might be in order.
Oh yeah, ignore the above and get a good set of rear gears before the cam and maybe a TC too, then do the cam swap.
$522 @ http://www.superchevyperformance.com :seeya :flag
This is Jeffs web site.
[Modified by C4Crazy787, 3:26 PM 3/25/2003]
[Modified by C4Crazy787, 3:27 PM 3/25/2003]
