86L-98 Firing order?
Old 03-28-2003, 10:18 PM
CLUTCH^Master
CLUTCH^Master's Avatar
Default 86L-98 Firing order?
Whats the firing order on a 86 w/ aluminum heads?
Old 03-28-2003, 10:23 PM
Nathan Plemons
Nathan Plemons's Avatar
Default Re: 86L-98 Firing order? (CLUTCH^Master)
Same as any other SBC
1-8-4-3-6-5-7-2
:cheers:
Old 03-28-2003, 10:31 PM
CLUTCH^Master
Default Re: 86L-98 Firing order? (Nathan Plemons)
thanks
Old 03-28-2003, 11:27 PM
CLUTCH^Master
turns out i need another combo, can someone help :banghead:
Old 03-28-2003, 11:33 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
:confused:
Old 03-28-2003, 11:37 PM
CLUTCH^Master
Default Re: 86L-98 Firing order? (Caboboy)
I tryed that combo and it doesent seem to work. car runs for half a second and dies.
Old 03-28-2003, 11:43 PM
severe-1
severe-1's Avatar
In what location is the #1 plug wire in relation to the distributor?
Old 03-28-2003, 11:49 PM
CLUTCH^Master
Default Re: 86L-98 Firing order? (severe-1)
drivers side closest to the radiator,(distributor is the one closest to the front drivers side as well)
Old 03-29-2003, 12:04 AM
severe-1
severe-1's Avatar
The distributor cap has a square section on the drivers side where the power/tach wires plug in. the # 1 plug wire needs to be plugged in to the second "post" in a clockwise rotation from this square block. This is the # 1 spark plug location. One off in either direction will cause the car to do what you described above.
The square block should end up between #7 & #2.
[Modified by severe-1, 12:06 AM 3/29/2003]
Old 03-29-2003, 12:11 AM
CLUTCH^Master
Thank you very much. I will check the car and hopefully that will be the problem.
Old 03-29-2003, 12:12 AM
severe-1
severe-1's Avatar
:thumbs: :flag
Old 03-29-2003, 12:20 AM
CLUTCH^Master
well those wires are where they need to be but my problem could be that i'm refering to a camaro manual and and i don't know if its the same firing order as mine. :confused:
Old 03-29-2003, 12:23 AM
severe-1
severe-1's Avatar
All small block chevy's are the same, from 1955 to 1998.
Old 03-29-2003, 12:33 AM
CLUTCH^Master
ok it kinda runs for a millisecond and dies, i rev it it dies, the firing order is in as you all stated. it shoots up a service engine code. any ideas on what i did wrong?
Old 03-29-2003, 12:41 AM
severe-1
severe-1's Avatar
What did you do in the first place when all this started?
Old 03-29-2003, 12:48 AM
CLUTCH^Master
(from the begining) my car had a miss fire in it. i the changed the fuel filter and it made it a little better but the miss remained. so today i replaced the cap and rotor and it got a little worse. then i began listening to differant web sites and i changed my firing oder 5 times and tryed to start the car. a couple of times the car would start but the car would miss even worse. so now we went back and followed the maunal and now the car will turn on the die right away and i don't know if i messed up the timing or what. :banghead:
Old 03-29-2003, 01:05 AM
severe-1
severe-1's Avatar
Unless you turned the distributor, you did not change the timing...
Pull the cap again and double check everything. Also check the coil and the connections to it.
To 86L-98 Firing order?
Old 03-29-2003, 01:09 AM
CLUTCH^Master
yeh, i am pulling the whole thing apart again as we speak, something is just not right.
Old 03-29-2003, 01:30 AM
Wheelman
Wheelman's Avatar
pull the code and see what it is..........
Old 03-29-2003, 02:29 AM
CLUTCH^Master
Default Re: 86L-98 Firing order? (Wheelman)
ok i just finished puting it back exactly as it was before i did anything to it? It still will not run. I was a litle low on gas so i added 5 more gallons, still not runing? what the hell. its just those 3 brackets and bolting the thing down! I am rely geting frusterated
Quick Reply: 86L-98 Firing order?
