Superram 1/4 mile times
Old 04-05-2003, 08:56 PM
91superram
91superram's Avatar
Default Superram 1/4 mile times
What is everyones 1/4 mile times with a superram set up
Old 04-05-2003, 10:17 PM
91superram
91superram's Avatar
Default Re: Superram 1/4 mile times (91superram)
There's got to be some fast Superrams out there?
[Modified by 91superram, 3:13 PM 4/6/2003]
Old 04-05-2003, 10:19 PM
chucks88
chucks88's Avatar
I can take mine off and put it back on in about 4 hours :jester
Old 04-05-2003, 10:26 PM
91superram
91superram's Avatar
Default Re: Superram 1/4 mile times (chucks88)
Thats pretty good it takes me at least 12 hrs
Old 04-05-2003, 10:56 PM
J Z06
J Z06's Avatar
Mine was on and off the car T W O times last year :)
my best e.t. with the sr is 11.84/117 on drag radials(1.71 60' :U )
Old 04-05-2003, 10:58 PM
scorp508
scorp508's Avatar
Default Re: Superram 1/4 mile times (JD 90 383)
12.89 @ 109.66 :U
2.2x sixty foots :U
Plenty more in her to go if I can stop breaking it every 3 weeks. :thumbs:
Old 04-05-2003, 11:37 PM
MrNuke
MrNuke's Avatar
That include your lower intake? or just the upper plenum/runners.. :lol:
I've had to take my plenum off 2 times within the past month, due to :
Forgetting about the Kickdown cable.
Forgetting about the EGR Valve and vacuum hose to the TB.
And it is coming off again this week to fix some oil leaks from the lower intake. :mad I got it down to no time at all to remove the valve covers, plenum and runners..
Now to the goods :
No times yet, but the car pulls like a madman to 5500+ rpms, as before she was starting to lose breath at 4800 and maxed at around 5K.. Totally different than the SLP siamesed runners/intake setup I had before.. Can't wait to fix the little problems and head to the track.. Hopefully I'll have some good 17" tires by then..
[Modified by MrNuke, 11:39 PM 4/5/2003]
Old 04-06-2003, 12:20 AM
91superram
91superram's Avatar
Default Re: Superram 1/4 mile times (scorp508)
Im hoping to get the same times out of my car,what is your set up
[Modified by 91superram, 3:14 PM 4/6/2003]
Old 04-06-2003, 10:33 AM
The Dingo
The Dingo's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
12.89 @ 109.66 :U
2.2x sixty foots :U
Gee Scorp, that makes those of us whose cars are still in the 13"s feel really good about it... :nopity
edit: 13.5@something around 103-104mph from memory here.
[Modified by Red 90 L98 Coupe, 1:34 AM 4/7/2003]
Old 04-06-2003, 11:15 AM
91superram
91superram's Avatar
Default Re: Superram 1/4 mile times (Red 90 L98 Coupe)
Red 90 l98 Coupe
What is your motor set up from intake to gears?
I want to get a feeling of where I stand since I am going out
to the track with this set up for the first time
[Modified by 91superram, 4:16 PM 4/6/2003]
[Modified by 91superram, 4:18 PM 4/6/2003]
Old 04-06-2003, 12:01 PM
The Dingo
The Dingo's Avatar
Forced air intake, SR upper and lower manifolds, relocated MAT sensor (probably no gain there), 52mm throttle body, stock exhaust manifold with no precats, B&B TriFlo cat-back exhaust (untouched main cat), single mass flywheel, 3.33 diff gears, ZF 6 speed, 285/40/17 Michelin Pilots, 180 thermostat and 185-200 degree fan switch, no frisbee, K&N filter (removed for 13.5 run), no spare. I think that's everything...
I'm going back in a few months (winter) to see if I can improve on this before I get my headers and put them on. These numbers were done on a hot, humid summer day and I was not expecting them. My previous best with the SR (14.0) was slower than my earlier runs with the stock runners on the SR base (13.7@101mph) both these times were made before the forced air, 285/40 michelins, and spare tire delete.
HTH
[Modified by Red 90 L98 Coupe, 3:05 AM 4/7/2003]
Old 04-06-2003, 02:25 PM
jburnett
jburnett's Avatar
Wife's 1985- 383" built by yours truly, 470hp, 505tq. On drag ET Streets this car has gone 11.77 at 119. I also ran a S/R on my 1990 model for several years...Best ET was 10.80 at 127 on heads/cam, stock shortblock with a 150 shot of N2O...Best N/A time with this combination was 12.18 at 115...
-Jeb Burnett
Old 04-06-2003, 05:24 PM
AS84
AS84's Avatar
Default Re: Superram 1/4 mile times (jburnett)
Last year it went 12.3 @ 112 with a 1.95 60' and a mail order chip. After some dyno tuning with a pocket programmer the car has so much more. I promise 11.9's this season on bfg's.
Old 04-06-2003, 09:18 PM
91superram
91superram's Avatar
Default Re: Superram 1/4 mile times (AS84)
Great 1/4 mile times what are you running for a bottom end
Old 04-06-2003, 10:40 PM
hookedup
hookedup's Avatar
10.93@125, 1.41 NA :D
[Modified by new92racer, 9:07 PM 4/8/2003]
Old 04-07-2003, 06:02 PM
91superram
91superram's Avatar
Which pocket programer were you using?
Old 04-07-2003, 06:38 PM
AS84
AS84's Avatar
Everything is stock, except for what's in my sig. The tuning setup actually belongs to a buddy of mine. We use my laptop and he has a the tuner cat setup. Works great! The last time we were on the dyno, my computer was acting up so we couldn't tune on the spot. A/F was at an average of 10.8 all across the board. On a mustang dyno with terrible A/F it dynoed at 300rwhp and 360rwtq. I assume the A/F is still a little rich, but it runs so much better now :yesnod:
Old 04-08-2003, 11:59 AM
The Dingo
The Dingo's Avatar
:eek: :eek: :thumbs:
Old 04-08-2003, 12:24 PM
jburnett
jburnett's Avatar
There is a caveat attached to that though... Cast pistons DO NOT like routine shots of nitrous in the 150 range...Two weeks after that time was posted I holed #8 and the wrist pin took out the block shortly afterwards. :nonod: No biggie...Just built a motor that would do that n/a...
-Jeb
To Superram 1/4 mile times
Quick Reply: Superram 1/4 mile times
