L98 crank, forged? other engine spec questions
Does an L98 engine in an '86 come with a forged crank? Also, is the block a 4 bolt main? Are the pistons forged aluminum? This engine has the aluminum heads. Thanks for the help.
Re: L98 crank, forged? other engine spec questions (burners)
No, no, and no.
A little over halfway through the model year the coupes got aluminum heads. Chevrolet didn't start producing the convertible until midyear, the same time that the heads were changed over to aluminum. So all of the 'verts came with aluminum heads.
Ok, so I guess the short block is really nothing special. Is it a one-piece rear main seal?
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: L98 crank, forged? other engine spec questions (MrNuke)
Nope, unfortunately we didn't get the 1 piece rear main... :nonod:
If you have a 2-piece, you'll be thankful if you have to change it, its much easier. :yesnod: Of course, with the one piece, it probably wouldn't need to be changed in the first place. :rolleyes: :smash:
[Modified by CentralCoaster, 1:01 PM 5/5/2003]
2 peice rear main?! Does that mean I can sneak it out and replace the thing? :eek: It is leaking ATM. :cuss
Re: L98 crank, forged? other engine spec questions (BookSmart)
Re: L98 crank, forged? other engine spec questions (CentralCoaster)
I've heard different stories as to whether the rear main was changed beginning of the 86 model year, or halfway though, and whether or not it corresponded to the change to alum heads.
