Where can I buy a "Torx security bit" for Fuel pressure regulator?
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The autoparts store doesn't have one. Think this is something Sears might have? I have a used AFPR, and no bit to take it apart and clean it with.
Re: Where can I buy a "Torx security bit" for Fuel pressure regulator? (CentralCoaster)
Try a local hardware store like Lowes or Home Depot. I got mine at a local home improvement store in Japan as part of a small set of bits for those interchangeable screwsdrivers.
Chris
Chris
Snap-on sells them.
OR
You can break off the pin in the center and use a regular torx bit, just like the dealership!
:smash:
OR
:smash:
Elite Torch Red Member
Re: (scorp508)
I found them at a local hardware store. $5 These are not volume items, so Lowers & HDumpo is a long shot.
Every once in a while I find a very well stocked hardware store. Every area usually has one somewhere.
Re: Where can I buy a "Torx security bit" for Fuel pressure regulator? (War Machine)
I bought mine at Big A Autoparts. I had to buy the whole set, but it was only about $10 or $12, and now if I ever need to take apart the divider walls in a public rest room, I'll be all set with the proper tools. :D
Re: Where can I buy a "Torx security bit" for Fuel pressure regulator? (Jim85IROC)
Can also get at electronic parts stores Tandy etc as they are used on security and alarm systems.
