Hub difference between 84-87 and 88-96
Someone posted a question on here a couple weeks ago about what exactly makes the hubs spaced further apart on the 88-96 from the 84-87. Can someone simply change the wheel bearing/hub assempbly on a 84-87 to the 88-96 or are the uprights/knuckles different? Anyone know what the difference is and if the early models can be converted easily? :confused:
Re: Hub difference between 84-87 and 88-96 (loiq)
I know the knuckles are different, and I believe even the `84 knuckles are specific to the year (dunno if `85-87 knuckles are bolt on or not). I believe you also have half-shaft length and associated suspension parts to worry about (tie rod ends, spring, spindle support rods...) because the offsets are so different.
In other words, to swap in a later (88+) rear, I *believe* it has to be virtually everything but the diff. - But I'm not 100% on that.
:cheers:
:cheers:
I'm not sure about the rear, but I know to transplant new hubs and stuff to the front you will need new upper and lower a-arms. That's where I got stuck at, so I gave up transplanting a '94 brake setup on my car..(Which by the way will be up for sale soon).. :D
I'd believe that Ramanstud. I wonder why GM changed it? :skep:
Received 1,400 Likes
Re: Hub difference between 84-87 and 88-96 (Ramanstud)
Things were redesigned because of the new suspension geometry, and the larger wheels/brakes.
GM felt that people complained so much about ride harshness in the early models that it needed to be redesigned, and the need to compete with other sports cars in braking. (Corvette was already one of the very best, but GM wanted to stay at or near the top.)
