Gas smell on start up.
When I start may 85 I have a strong smell of gas initially. Yesterday I noticed a small wet gas spot under the rear after it idled a minute in the drive. I drove all day and smelled it each time I started up for a few minutes then it was gone. Didn't see any more leaks though?? What should I be looking at? :confused:
Re: Gas smell on start up. (Gregory VanLare)
Is it running any different? It could be alot of things MAF going bad, CAT Backing up not burning off,Fuel Pressure Reg, leaking injector, I would do a fuel pressure check on the rail and clamp off the return line and see if the pressure drops. Do you have a manual?
1 Post
St. Jude Donor '04
Re: Gas smell on start up. (Mach85)
