Help with warning lights?
Old 05-18-2003, 09:32 PM
Breezy
Breezy's Avatar
Default Help with warning lights?
I recently began getting "service abs" and "service asr" warning lights intermittently. When I shut off the car and start it up again they are gone. I checked the trouble codes and I am not getting any. I recently got new tires and a four wheel alignment. Never got the lights before that so I took it back to the shop and made them put it on the hoist to look for bad connections or ?
They say they never got near any of the sensors connections and I think they are probably right. Does anyone have a clue?
I almost forgot to mention that I had the brakes serviced about 3 months ago. Pads and rotors turned.
[Modified by Breezy, 6:34 PM 5/18/2003]
Old 05-18-2003, 10:29 PM
bogus
bogus's Avatar
Default Re: Help with warning lights? (Breezy)
check the level of brake fluid. I have found that whenever I do a brake bleed, there is some residual settling and/or air that is left in the system.
Old 05-19-2003, 08:23 PM
Breezy
Breezy's Avatar
Default Re: Help with warning lights? (bogus)
Thanks bogus but my fluid level is ok.
To Help with warning lights?
Quick Reply: Help with warning lights?
