ZZ4 cam for A4 lt1 upgrade???????????
just read that there is a better cam than the hotcam for my lt1 A4... I'm about ready to do hotcam kit..........IS THERE A BETTER SET-UP??? :confused: :confused:
St. Jude Donor '13
Re: ZZ4 cam for A4 lt1 upgrade??????????? (redcorvettedave)
Pending how you drive your car, the HotCam is good and bad. The Hotcam makes less torque and HP under 4500rpm and peaks higher. THe ZZ4 will make more usuable HP and TQ for a daily driver below 4500rpm and for those speratic fun days when the peddle hits the flow.
In an auto car, you will need a higher stall converter and taller rear end, otherwise the hotcam is too much cam for the auto.
Vic
Vic
Re: ZZ4 cam for A4 lt1 upgrade??????????? (89'Bowtie)
already got 3.54s ...my car is a daily driver.....I want the best of both ... low end tor... and top end POWER!!!!!! :smash: p.s. I going to get 2200-2400 stall tc
[Modified by redcorvettedave, 10:36 PM 5/25/2003]
Received 1,401 Likes
Re: ZZ4 cam for A4 lt1 upgrade??????????? (FoolCrzy)
Hotcam kit for you.
