How hard is it to change the fuel pump ?
I'm hearing a weird wine coming from somewhere underneath the passenger side of my 89. Someone told me it might be the fuel pump? How hard is the fuel pump the replace?
Cruise-In V Veteran
Re: How hard is it to change the fuel pump ? (red_89_vette)
Fuel pump is in tank, not a hard job. Possibly the sound might be travelling.
You should hear the pump prime your system when you first turn the key.
Give a little more detail and perhaps others will chime in.
Re: How hard is it to change the fuel pump ? (85vet)
thanks
I've done it twice. It's not hard, but I did have trouble finding a new gasket for the top of the tank. The sock runs lengthwise same as the car.
Cruise-In V Veteran
Re: How hard is it to change the fuel pump ? (Mark L. Warner)
Mark is correct. You can get the gasket from zip products. They are a supporting vendor and you can take 10% off if ordered through forum.
Well it would be my cousin helping me do this. He's done his fuel pump in his firebird formula before and he didn't have any trouble. I think it might be the cause of the whining noise. The noise is bad till about 2300 RPMS in first, but then it cuts off. It usually does it pretty loudly when the car idles, but it will do it sometimes when the car is accelerating off the line.
Where abouts is the fuel pump, like do we have to drop the tank and to get to it? Can anyone give me instructions and steps for how I would go abouts doing this?
thanks for your help
Re: How hard is it to change the fuel pump ? (hippy)
1. Remove the fuel pump fuse.
2. Start the car and let it stall from running out of gas.
3. Remove the gas cap.
4. Try to start the car for 10 seconds.
5. Remove the rubber gasket thing around the filtler neck.
6. Remove the 4 torx bolts holding the filler plate down.
7. Yank the filler plate.
8. Unplug the wires.
9. Remove the 3 hoses from the plate making note of where each one goes. Careful, the supply line may have gas in it still, so have a towel handy.
10. Remove the 10 or 12 bolts holding the assembly down.
11. Pull the assembly up and out.
It is pretty straightforward from there. :)
Cruise-In II Veteran
Unlike the F-body you don't have to drop the tank; that's why it's a piece of cake (maybe the easiest repair on the C4).
-buy an AC Delco pump and pickup screen
-remove the filler door and rubber boot
-unplug the connector to the fuel pump and crack the gas cap loose
-disconnect the three gas lines and cap if necessary to prevent seepage
-remove the ring of bolts around the retainer ring and lift the pump assembly straight up out of the tank.
-note orientation of the pickup screen and follow directions to install the new pump and pickup.
-reverse the above procedure to wrap it up.
Plan on 1/2-1 hrs for his job.
Re: How hard is it to change the fuel pump ? (65Z01)
ok, just tested the fuel pressure with a gauge on the test port. Key on the pressure is only at about 20psi, after extended cranking it fires at about 40psi. I'm assuming the fuel pressure should be similar to my cousin's on key on (40psi). So we're thinking it's the fuel pump. Anyone agree/disagree? Could it be a leaky injector?? I doubt it since the pressure seems to hold at 20psi when you turn the key on.
We're almost positive it's the fuel pump just wanted to hear what you guys have to say. Thanks in advance.
20 is real low with key on.
When you turn the key on the pump only runs for about 2sec so a weak pump may not fully prime the fuel rail.
When I turn my key on the rail primes to a over 40psi.
Since it holds well after you shut off the engine I doubt you have a leak.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: How hard is it to change the fuel pump ? (Darkness)
Does that noise from the passenger side of the car, happen mostly on cold startups? It's not the fuel pump (its in the tank).
I'm pretty sure it's actually chatter in the lines. Similar to water-hammer that might happen in your house's water pipes if you turn the faucet on or off to quick.
It's a very common problem, but I have yet to see anyone that knew what caused it. There's supposed to be some sort of dampener in the fuel line to prevent this, so maybe that failed somehow. Or maybe it's caused from air being in the lines on startup, from leaky injectors of a bad fuel pump check valve.
Let us know if the new pump cures the noise though. :yesnod:
Re: How hard is it to change the fuel pump ? (scorp508)
Step #4a - DISCONNECT THE BATTERY
But that's just me
[Modified by Slalom4me, 11:17 AM 6/3/2003]
