How much does an LT-1 aluminum block weigh?
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
Re: How much does an LT-1 aluminum block weigh? (LT-4 CE)
Good to know. I wasn't sure and a friend of mine thought they were aluminum and was curious. I guess the more appropriate questions would be, were LT-1 blocks made in aluminum? And now I know the answer.
Thanks for clarifying.
You'll probably want to do a search on LT1 engine wieght, but the LT motors are the heaviest (at >600 lbs) of the GM Al headed motors. Yes L98's do weigh less.
Cruise-In I Veteran
Cruise-In II Veteran
Re: How much does an LT-1 aluminum block weigh? (Chefskeez6)
I didn't know LT1 blocks were available in aluminum?
Re: How much does an LT-1 aluminum block weigh? (Lone Ranger)
The LS1's are aluminum block and aluminum heads (four-bolt aluminum block with cross-bolt mains) :yesnod:
Re: How much does an LT-1 aluminum block weigh? (JasonL)
Most aluminum smallblock blocks weigh in the neighborhood of 90-100 lbs. (with nothing in them)
The LT1 weighs 22lbs more than an L-98, due to the cast iron exhaust manifolds.
-Dave C.
-Dave C.
