Hesitation and Jerking 94 LT1 Corvette
Old 06-21-2003, 05:11 PM
C4CAT
C4CAT's Avatar
Default Hesitation and Jerking 94 LT1 Corvette
I was cruising at about 2000 RPM in 3rd gear and I decided to punch it, the car hesitated and jerked violently :confused: This is the first time that this has happened. I also notice that somtimes when I take-off in 1st gear it bucks around, especially when the Air Conditioning is running. What could this be? I have a new clutch and resurfaced flywheel :confused: Should I get a new flywheel? The car has 55,000 miles and it's a 1994 LT1 Corvette :chevy
[Modified by C4CAT, 10:12 PM 6/21/2003]
Old 06-21-2003, 05:25 PM
SPEED750
SPEED750's Avatar
Default Re: Hesitation and Jerking 94 LT1 Corvette (C4CAT)
Send some more symptoms.Kinda sounds like fuel delivery problem.If my 92 has less than a 1/4 tank and I punch it , it will buck and kick like (fuel on-fuel off)Does it do this with a full tank?Have you changed the fuel filter lately? :steering:
Old 06-21-2003, 05:46 PM
C4CAT
C4CAT's Avatar
Default Re: Hesitation and Jerking 94 LT1 Corvette (SPEED750)
It had a full tank of the 93 octane from Mobil :yesnod: I'll look into the fuel filter :skep: The dealership usually let's me know about all maintenance needed. How often does the fule filter need changing?
Old 06-21-2003, 05:57 PM
SPEED750
SPEED750's Avatar
I change my fuel filter every 10,000 miles(ish) It,s just cheap insurance.When your have'n the problem,does it feel like the tranny-clutch?The motor sounds good but the car is jerking? :steering:
Old 06-21-2003, 06:33 PM
ittlfly
ittlfly's Avatar
Put a fuel pressure guage on the schrader, tape it to the windshield and take the car for a ride. If it's bucking and the pressure falls way off, take a hard look at the pump.
Old 06-21-2003, 07:35 PM
bheston
bheston's Avatar
It almost sounds like an opti-spark. When my died the car bucked and kicked so bad it actually caused two spark pug wires to fall off the plugs!
Make sure your spark plug wires are on good. If you haven't washed your engine like I did, your opti-spark may be fine.
[Modified by bheston, 12:36 AM 6/22/2003]
Old 06-21-2003, 07:44 PM
C4CAT
C4CAT's Avatar
Speed 750 you hit the nail on the head with that description
Old 12-05-2016, 07:48 PM
pkincy
pkincy's Avatar
Puhlease make sure the Shrader valve is tight when you do this. I missed that step once and was incredibly lucky I didn't burn the car down as when I got back to take the FP guage off, I saw that it had sprayed raw fuel all over the engine compartment.
Old 12-05-2016, 07:54 PM
antfarmer2
antfarmer2's Avatar
Change the front two o2 sensors and hang on it will be a new car.
Old 12-05-2016, 08:16 PM
arbee
arbee's Avatar
I'm guessing he has found a solution. Been 13 years since this was posted.
Old 12-06-2016, 01:34 AM
antfarmer2
antfarmer2's Avatar
Did not notice that, but it will still help others.
Old 12-07-2016, 02:33 PM
lt4obsesses
lt4obsesses's Avatar
Or, Pkincy's advice is 13 years too late...
To Hesitation and Jerking 94 LT1 Corvette
Quick Reply: Hesitation and Jerking 94 LT1 Corvette
