LT4 rockers??
LT4 rockers??
Will the LT4 rollers that come with the LT4 hot cam kit bolt up to my stock LT1 heads or do I have to change the studs? What size are the studs on the LT4 heads?
Re: LT4 rockers?? (ejfagala)
The rockers that come in the HOT Cam *kit* will bolt on to your LT1. The LT1 uses a 3/8" stud :yesnod:
Although they look the same as what's in the HOT Cam kit, OEM LT4 rockers are designed to work with the OEM LT4 10mm shouldered stud.
