Blue smoke?
Blue smoke?
Here is the situation:
I have installed new cam, valve springs, retainers but I reused old
valves and guides ( valves and seats were machined ).
Before any work done, engine worked great ( 16000 orig. miles ).
Now I have blue smoke coming from exhaust. Mostly on startup but
also while driving on deaccelerating and also while idling.
I know that it's normal that after all the work that I've done to engine,
and since everything was oiled ( valves, guides, cylinders...) before
assembling, that it will smoke on first start, but now the engine
worked 1-2 hours and it's still smoking.
I have new valve seals on intake valves and no seals on exhaust
( there were no seals originally ). New o-ring seals on all valves.
What do you think is wrong?
Re: Blue smoke? (Sliding)
Deaccelerating and getting blue smoke,sounds like a valve seal,guide issue to me.
Are these umbrella seals ?
[Modified by AGENT 86, 6:49 AM 8/11/2003]
Re: Blue smoke? (Podracer)
The exhaust does'nt have seals so they get extra oil, there is no vacum on the exhaust side to pull oil down to lube the guide.
as for the smoke I think you tore the seals when you put them on. Did you put the O ring on ALL the valves? at 16,000 mi. your valve guides are fine.
Re: Blue smoke? (offershore)
Bad guides really make no sense since I didn't even touch them and there
was absolutely no smoke or oil consumption before any work.
I was very careful with valve seals on intake ( Crane teflon valve seals )
so I don't think that I broke any.
Mine did that after I changed the springs and used the old guide seals.
But the good news. It stopped after a while. Probably about a month.
I think I just pushed the seals down too hard on installation.
Drive it a while and see...
Re: Blue smoke? (92corvette)
Did you use the sleeve when yuo put the seals on?
I still didn't have chance to drive much because of work but I'll
get to it next week.
