1993 Front bumper removal
2nd Gear
I would like some information as to how to remove the front bumper from my 93 vette. Any information would be helpful and diagrams would be great. Thanks!
Re: 1993 Front bumper removal (LVCoz)
I thought about replacing my turn signal/driving light lenses until I read in the service manual how much needs to be done to remove it. Looks like QUITE a chore. Sorry I can't help you out with how to do it. Here is a ttt for ya. Good luck!
Removing the bumper on my 89 is not an easy job. I have had if off twice due to repaint and a wreck. The first removal took about 3 hours as I was not sure of what I was doing. The second time took about a hour. Taking it off is the easy part as putting it back on will take 2 to 3 times as long to remove it. Removal requires working above and below the car. I have a GM Helms manual which describes the procedure. It is too long to type here. Let me know if you want a fax copy on Monday.
2nd Gear
Re: 1993 Front bumper removal (Sam Lam)
Would grealtly appreciate it if you were able to fax me a copy of the procedure. My Fax number is 702 396-5739 after 9am Pacific time. Thank you in advance!
