Headlight change?
Headlight change?
I have a 92 and want to change out the sealbeam bulbs. Is it standard procedure to remove the bezel (covers top of bulb unit) to replace the bulbs? You can't just remove the retaining ring that holds the bulb in? Better yet, what's the best way to change out the bulbs? Thanks Gents :cheers:
Re: Headlight change? (Strick)
Remove the screws holding the cover on (I think there are 4). Remove two of the screws holding the retaining ring. Bend down the retaining ring and pull out the headlight. Reverse procedure to reassemble. It doesn't take long. :cheers:
