Shortie headers for 1986 vette
I have checked with Hooker, Hedman, Tpis etc. and no one seems to make a shortie header for the earlie C4 . All make long tubes but no shorties. Is that because there would be no advantage over the factory manifolds( I doubt it).
Does anyone know of anybody who makes shorties for an 86 C4 ?
If you must have a shorty, check out the slp's made for lt'1s. They'll go right on, and I don't think the lack of air tubes would cause problems except for perhaps a visual emission's inspection.
we had a member on here buy mackeyred96's lt1 shorties for his '90 l98 and had no problem with them. :cheers:
Received 1,400 Likes
Re: Shortie headers for 1986 vette (dwestsr)
Provided your car is in tune and the EGR setup works, you can pass NC emissions tests with longtube headers and a good main cat.
Shorties are basically only going to give at most 5-7hp, then some weight savings.
Whereas the LTs will give about 15hp
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Shortie headers for 1986 vette (vader86)
Re: Shortie headers for 1986 vette (CentralCoaster)
Where did you get these numbers from? :skep:
