Anyone seen a 1985 corvette piston? Stock?
Old 09-18-2003, 11:30 AM
MrNuke
MrNuke's Avatar
Default Anyone seen a 1985 corvette piston? Stock?
I am trying to find out what kind of piston design is in the '85 stock engine.
Are they flat top, or not? I knwo they are forged and stock compression is supposed to be 9.5, but that's about it.
Thanks.
Old 09-18-2003, 11:36 AM
jburnett
jburnett's Avatar
Default Re: Anyone seen a 1985 corvette piston? Stock? (MrNuke)
Yes...It's an OEM 4013 design sourced from TRW by GM. Flat-top with 4 valve reliefs and heavy as lead!
-Jeb
Old 09-18-2003, 11:47 AM
Bluevette85
Bluevette85's Avatar
Default Re: Anyone seen a 1985 corvette piston? Stock? (jburnett)
Yes...It's an OEM 4013 design sourced from TRW by GM. Flat-top with 4 valve reliefs and heavy as lead! -Jeb
The 85 pistons are forged flat top with one long relief across the top not four. I'll post a picture tonight.
Old 09-18-2003, 12:08 PM
MrNuke
MrNuke's Avatar
Default Re: Anyone seen a 1985 corvette piston? Stock? (Bluevette85)
Thanks guys, Trying to figure out what sort of compression I would have switching to new heads.
Anyone know how to figure it out?
If I went to 58cc, 64cc, 67cc, 72cc, 76cc?
I know the stock heads are 82cc.
Old 09-18-2003, 12:10 PM
neverendingproject
neverendingproject's Avatar
:iagree: i have 8 of em sitting in my storage room right now, 1 long valve relief.
b.t.w. are the x rods worth anything?
[Modified by neverendingproject, 5:11 PM 9/18/2003]
Old 09-18-2003, 12:19 PM
Bluevette85
The stock 85 heads are 76cc and compression is 9.0:1.
When I put on the 113 aluminum heads (58cc) and a 0.05" head gasket, my compression went to 10.6:1.
Old 09-18-2003, 12:21 PM
Pete Pulos
Pete Pulos's Avatar
Pi x Radius squared = area of circle
area of circle x stroke = cc of cylinder
Convert the bore and stroke to centimeters 1" = 2.54 centimerter
Pi is 3.14
Figure the maximum volume of the block at bottom stroke and add the cc of the head
Divide max volume by minimum volume
you will also need to calculate the head gasket volume the same way and add it to the equation
Old 09-18-2003, 01:53 PM
okinawa86vette
okinawa86vette's Avatar
When I took the heads off my old '85 parts car, they were flat with one long relief.
There's some really good compression calculators on the internet that take into consideration everything from heads, pistons, all the way down to the head gasket thickness. I should have a couple bookmarked at home, so when I get home tonight, I'll see if I still have them and I'll post their links.
Chris
Old 09-18-2003, 10:29 PM
Bluevette85
Picture as promised:
[Modified by Bluevette85, 10:38 PM 9/18/2003]
To Anyone seen a 1985 corvette piston? Stock?
Quick Reply: Anyone seen a 1985 corvette piston? Stock?
