LT1 cam in L98: would it work?
Received 1,400 Likes
Re: LT1 cam in L98: would it work? (DSKRALL)
The profiles are so similar that you wouldnt get much.
The main power-related difference between the two engines is the intake.
Re: LT1 cam in L98: would it work? (vader86)
the LT1 cam has a bit more lift than the L98 bumpstick... duration is almost identical between the 2.
if youre going to go through all the trouble of swapping cams, put a better one in than the stock LT1. you wont see much of a power difference. good choices are the ZZ9, LPE 211, or the CompCams grind (cant remember the part#) with 212/218* duration
