L98 Valve Adjustment - Best Conditions for Adjustment?
Old 11-26-2003, 04:37 PM
geezel
geezel's Avatar
Default L98 Valve Adjustment - Best Conditions for Adjustment?
When adjusting valves with aftermarket roller rockers (without engine running), what are the best conditions for the most accurate adjustment? Engine cold? Engine warm? Does it matter if the engine has not been started for several days?
Old 11-26-2003, 05:12 PM
85blkZ51
85blkZ51's Avatar
Default Re: L98 Valve Adjustment - Best Conditions for Adjustment? (geezel)
You can set them cold, but the final should be done after its warmed up.
Old 11-26-2003, 08:45 PM
CFI-EFI
CFI-EFI's Avatar
For a hydraulic cam, it makes no difference. Unless you are setting the preload at the absolute minimum, then I like to set them with the engine running. For solids the spec is usually stated, such as, "hot lash". In that case, I warm it up and do one side at a time. I then re-warm it to do the other. After it cools, I check to see what it is cold. Using that info, you can set them cold from then on. Good luck, and...
RACE ON!!!
Old 12-01-2003, 06:50 PM
geezel
geezel's Avatar
Default Re: L98 Valve Adjustment - Best Conditions for Adjustment? (CFI-EFI)
OK... I'm presently set at 1 full turn from zero lash without engine running (too tight I understand). If I readjust to say, 1/4 turn with engine running, I assume I back off nut until I hear clatter, tighten until clatter just stops, then 1/4 turn more. Is this correct?
Old 12-01-2003, 06:55 PM
grapeknutz
grapeknutz's Avatar
St. Jude Donor '06
:thumbs: That the way to do them!
Old 12-01-2003, 07:05 PM
CFI-EFI
CFI-EFI's Avatar
Is this correct?
That IS correct!
RACE ON!!!
Old 12-01-2003, 07:18 PM
chucks88
chucks88's Avatar
Maybe it was just me, but I had a tough time hearing the clacking. So when I wasn't sure on a given rocker I would hold a screw driver up to my ear from the rocker nut and I picked up sounds I couldn't hear with the naked ear. But you may be able to pick up the clacking
Old 12-01-2003, 09:30 PM
pablocruise
pablocruise's Avatar
I can ballpark them when cold, but
I like to have the motor warm and running so the lifters are pumped up with oil.
To L98 Valve Adjustment - Best Conditions for Adjustment?
Quick Reply: L98 Valve Adjustment - Best Conditions for Adjustment?
