L98 Idle question.
Old 12-05-2003, 01:38 AM
Trog
Trog's Avatar
Default L98 Idle question.
Okay, the baby is back on the streets & overall is running VERY well. I have to say the extra grip coil over shock conversion ride is a bit harsher than I expected but I'll live with it for the handling.
My question has to deal with idle, clutch in & car rolling, speed is not too important. Same at 5 mph to 50 mph. When rolling the idle seems to hunt, up & down from 800 to about 1100 RPM. As soon as I come to a complete stop the idle drops to 800 & stays there, smooth & clean. Does anyone else experience this &/or is this normal?? :confused:
Old 12-05-2003, 02:16 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Default Re: L98 Idle question. (Trog)
Though I don't feel it with my A4, my scanner shows that desired idle varies with speed/rpm and possibly with throttle position.
But I don't know if "hunting" idle with speed is normal.
Old 12-05-2003, 03:45 AM
NightRyder
NightRyder's Avatar
Default Re: L98 Idle question. (65Z01)
well, i know that with speed, and clutch engaged my idle stays at about 11 - 12 rmps. after i completly stop, it will slowly (over about 5-7 seconds) drop to 8.
Old 12-05-2003, 09:50 AM
LWesthaver
LWesthaver's Avatar
I've seen this same behavior on my car. As long as the car is rolling, the car stays around 900+ rpm. Once I'm fully stopped, it drops to around 650rpm. I always assumed this was normal. Is it?
:confused:
Old 12-05-2003, 12:57 PM
jmrl98
jmrl98's Avatar
Default Re: L98 Idle question. (LWesthaver)
The 650 idle is normal for my 85 4+3 :seeya
Old 12-05-2003, 01:10 PM
Trog
Trog's Avatar
Perhaps hunt was the wrong term for me to use. In an attempt to be more precise, the idle goes up & down between 800 & 1100 RPM. Almost like you were slowly turning the IAC up & down by hand. Its not all that rapid of a process about 1 or 1.5 seconds up & another 1 or 1.5 to go back down. I'm guessing that the chip in reading vehicle speed, RPM, vacum etc is thinking the idle is too low??
Old 12-05-2003, 06:23 PM
BBA
BBA's Avatar
Did you consider changes in vacuum level because of using brakes or power steering pump load in slight turning, or even A/C cycling?
There are many conditions where a little RPM will improve driving experiences, so I wouldn't think it's a bad thing...it may be by design. :)
[Modified by BBA, 6:24 PM 12/5/2003]
To L98 Idle question.
Quick Reply: L98 Idle question.
