85 interior door panels
Old 12-08-2003, 02:07 PM
helopilot
helopilot's Avatar
Default 85 interior door panels
The carpet on my interior door panels is pulling off the vinyl and I was wondering if anyone else has had this problem. I've tried regluing the carpet to the door panel but there's just a small "lip" of vinyl that the carpet is attached to and the carpet won't stay attached. I'd really like to try and fix this instead of spending a lot of $ on new door panels. Anyone else had this problem or able to repair? Thanks for any help! :flag
Old 12-08-2003, 02:15 PM
LD85
LD85's Avatar
Default Re: 85 interior door panels (helopilot)
Yeah, I pulled my 85's door panel soff and got long staples and stapled just under the round ribbon edge thru the door panel and then bent the staples over on the back side of the panel,,, brushed the carpet by hand and no one will ever know. :smash:
Old 12-08-2003, 03:05 PM
vinnies87
vinnies87's Avatar
St. Jude '03-'04-'05-'06-'07
Default Re: 85 interior door panels (ld85)
:iagree: Did the same thing with mine, after i purchased new carpet panels, even HOT glued them to the door,,, but the staples work great....
Old 12-08-2003, 03:26 PM
helopilot
helopilot's Avatar
Default Re: 85 interior door panels (vinnies87)
Thanks for your help guys, I'll give the staple idea a try!
Old 12-08-2003, 04:02 PM
Bilyk
Bilyk's Avatar
where did you purchase new panels from? i could use a new set
Old 12-08-2003, 04:06 PM
helopilot
helopilot's Avatar
Default Re: 85 interior door panels (Bilyk)
I haven't purchased new one, trying to avoid that since my originals are in really good shape (except for the carpet pulling off). I know Mid America carries new panels and probably Ecklers.
Old 12-08-2003, 06:05 PM
uralman
uralman's Avatar
replaced the carpet and used 3m spray contact glue. worked great. hard part was scraping the old glue off the plastic
paul
To 85 interior door panels
Quick Reply: 85 interior door panels
