Best Spark plugs for 94C4 are AC Delco Rapid fire spark plugs?
i've been told by my corvette mech that the AC Delco rapid fire spark plugs are the best for my 94 C4, would you concure? The big problem iam experencing is trying to find a parts outlet that sells rapid fire spark plugs.
dose anybody know where i can buy AC Delco rapid fire spark plugs. and if unavailable what spark plugs would be a good alternative? autolite plantinum,
AC plantinum, NGK V groove copper plugs ETC...
thanks boonie
thanks boonie
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Best Spark plugs for 94C4 are AC Delco Rapid fire spark plugs? (boonie2)
:cheers: They work great four me! I gap them .045 in my L98
I think I actually found my last set at a Walmart(ugh)
:seeya
:steering:
[Modified by jackdaroofer, 5:16 PM 1/24/2004]
:seeya
:steering:
Re: Best Spark plugs for 94C4 are AC Delco Rapid fire spark plugs? (jackdaroofer)
NGK IRIDIUMS.....IS HANDS DOWN THE BEST FOR YOUR 94 ..I HAVE A94 AND THUS FAR THEY ARE THE BEST...BUT MAKE SURE YOUR 02 SENSORS ARE GOOD THESE PLUGS FOUL EASY...THE NEXT PLUG I'M GOING TO TRY IS A RACING CUTBACK..TELL YOU LATER WHAT I THINK :D
thanks boonie
thanks boonie
You will need AC Delco Rapidfire #14.
Go in and tell the guy at the counter that is what you want, and just ignore him when he tells you those plugs aren't what's recommended for your car. Just be persistent and you'll get what you want.
I have them on my 94, and they work fine. Of course, I think I may have a high RPM miss because I got anti-seize on one of them, but that's an entirely different problem...
If you get NGK, just get the regular copper ones. I think they're like $1 something a piece at NAPA. No need to get the expensive iridiums unless you just like to tell people you have an expensive plug. All you need is a plug that makes a spark all the time. Copper will do that just fine.
Re: Best Spark plugs for 94C4 are AC Delco Rapid fire spark plugs? (redcorvettedave)
