Long Tube Headers for 1993 LT1??
Old 01-31-2004, 10:38 PM
Dark_Rider
Dark_Rider's Avatar
Default Long Tube Headers for 1993 LT1??
I can only find shorties for the LT1. Doens't somebody make a long-tube header? Thanks in advance if someone tell me where I can find some.
Old 01-31-2004, 10:43 PM
BBA
BBA's Avatar
Default Re: Long Tube Headers for 1993 LT1?? (Dark_Rider)
Thats because if you put long tubes in, you loose the cats and that wouldnt be legal.
You can use L98 long tube headers.
Old 01-31-2004, 10:53 PM
tobijohn
tobijohn's Avatar
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
AGAIN, the messed up archives bite us in the rear. I believe Exotic Muscle as well as TPIS sell long tube headers that work with cats (although not the stock ones) on both LT1 manuals and autos. Members have installed and commented extensively on both with the EMs seeming to come out on top. There are a number of threads with pics of the install but until the message bodies are restored to the archived posts, forget about it... :mad
Old 01-31-2004, 11:03 PM
Dark_Rider
Dark_Rider's Avatar
Default Re: Long Tube Headers for 1993 LT1?? (BBA)
Fortunately for me, OK doesn't require inpections so I'm not to worried about losing the cats. What year were L98's in? I'm a new corvette owner and am not that familiar with the history. Do you know of anything else that would bolt on?
Old 01-31-2004, 11:14 PM
DVNCI
DVNCI's Avatar
I've got Hooker Longtubes on mine, don't have a model number. If you check the website you can see a pic.
kevin
Old 02-01-2004, 07:56 AM
93 ragtop
93 ragtop's Avatar
Exotic Muscle sells a set for the LT1 that is a complete bolt on deal. They even sell pipes to connect back to the orig. exhaust or you can buy pipes and converters to tie back to the orig. set up. I have a set ordered which I hope to get this week or next week.
Old 02-01-2004, 09:44 AM
SPEED750
SPEED750's Avatar
Default Re: Long Tube Headers for 1993 LT1?? (93 ragtop)
The hooker part number is 2151. I've got a set coming from JET HOT that have been ceramic coated inside and out with bungs for the O2 sensors welded in. The price quote was $653 with shipping. They do not have the air tube hook up, but I'm gonna pull the air pump off the car and have a new chip burned so it won't throw any codes. FL doesn't have smog checks.
Old 02-01-2004, 09:53 AM
Dark_Rider
Dark_Rider's Avatar
Default Re: Long Tube Headers for 1993 LT1?? (SPEED750)
Do you need to jet coat them? Is it to reduce the heat for the surrounding parts?
Old 02-01-2004, 10:48 AM
SPEED750
SPEED750's Avatar
If you don't have your headers coated, they will rust away in no time.I went with the jet hot for alot of reasons.It will keep the under hood temp way down (cooler intake charge=more power) and it puts enough heat down the pipes so your 02 sensor doesn't have to be changed for a heated one.Plus they look great and will last for years.I think their ad shows a header temp of 225 degrees on RUNNING V8.After you shut off the engine, you can grab the header after it sits for only 5 minutes.These coatings work. :chevy
To Long Tube Headers for 1993 LT1??
Quick Reply: Long Tube Headers for 1993 LT1??
