Injector noise?
Injector noise?
I just put in some new injectors, FMS 24#, and they make quite a racket. Or is that something else? Sounds like you can hear them clicking on and off.
Location: Mississauga, Ontario Corvettes were built to be driven...not trailered
1 Post
St Jude Donor '07-'08-'09
Re: Injector noise? (Ras119)
Ras, thats pretty normal...check out the mustangs when they have their hoods open and are running...same thing. With the hood closed, you should not be able to hear them...if you can, there may be other issues like way to much fuel pressure or wrong injector type/setting
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I have them on mine they tick .I reduced fuel pressure and they quieted down a bit.But they are noisy.
