DRAG RACING RIM SIZE CHOICES?
JUST A THOUGHT, WOULD 15" RIMS FIT THE BACK OF A 92 VETTE. IF NOT HOW ELSE CAN YOU COME UP WITH A COMBO FOR DRAG SLICKS(NOT DRAG RADIALS)? ALSO, DOES ANYONE KNOW IF 95 TRANS AM WHEELS WOULD FIT MY 92. I WANT SOME DRAG RADIALS BUT DONT WANT TO PUT THEM ON MY NEW CHROME SAWBLADES. :confused:
Re: DRAG RACING RIM SIZE CHOICES? (DRAGRCR1005)
I had some 15 x 7 steel wheels off a s10 I put my et streets on. They fit with no brake issues. However they stuck out from the quarter panels about 1/2 an inch. You can get weld xp's that will clear and have the proper offset.
Weld 15X10s w/7.5"BS, 5/16 spacer, grind brake calipers to clear, 10.5x26 slicks clear, 10.5-11.5X28 need to raise it up 1".
Good luck,
Dave :thumbs:
Good luck,
Dave :thumbs:
Elite Torch Red Member
Re: DRAG RACING RIM SIZE CHOICES? (hookedup)
Good luck,
Dave :thumbs:
Good luck,
Dave :thumbs:
Re: DRAG RACING RIM SIZE CHOICES? (JordonMusser)
1988 on up needs a 7.5" back space with a 10" rim, otherwise the tires will stick out.
[Modified by tpi 421 vette, 2:50 PM 2/10/2004]
