Need Help
5th Gear
Need Help
I'm getting ready to put my new exhaust system on that I got from eckler's and the front Y pipe doesn't have a spot for the O2 sensor.......2 part question...will I need it for a visual emmision inspection in central Pa......and not having one make it run rough /lean or rich.
Re: Need Help (wingvette)
Without one the vehicle won't be able to get any readings when it is warmed up. You might be able to get your rodeo license though driving it that way! :D
St. Jude Donor '11, '14
Just go to the Auto Parts store and get the threaded part you need. I think it is called a bung. Have the muffler shop that installs the exhaust weld it in or them 4 if you have an LT 4.
Robin
:cheers:
Robin
:cheers:
