Push in clutch to start car.
Old 03-16-2004, 10:22 AM
Steelevette
Steelevette's Avatar
Default Push in clutch to start car.
It seems like I have to push the clutch pedal through the floor to get the car to engage the starter. I am assuming this is a switch. If so, can this be adjusted? I plan on looking everything over this coming Week-end.
Thanks. :)
Old 03-16-2004, 10:24 AM
Steelevette
Default Re: Push in clutch to start car. (Steelevette)
I forgot to mention the car in question is an 1989 with six-speed. Duh! :rolleyes:
Old 03-16-2004, 10:26 AM
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
:lurk: Whats wrong with pushing in the clutch to start it? :confused:
Old 03-16-2004, 10:36 AM
scorp508
scorp508's Avatar
Yes.
Why? Thats proper.
Old 03-16-2004, 10:45 AM
xs650
Support Corvetteforum!
xs650's Avatar
That's one of the safety faerie things I actually like. :cool:
Old 03-16-2004, 10:49 AM
bac22
bac22's Avatar
Default Re: Push in clutch to start car. (xs650)
I know they usually set these switches so that you have to depress the clutch to the floor. This is to ensure that the clutch is actually disengaged before starting the car.
If they didn't do this and later on down the road a person changes their clutch that engages at a different location then the original, it could make for a messy situation.
The switch if I remember correctly is right on the clutch pedal near the top.
Old 03-16-2004, 11:44 AM
94 M-6
94 M-6's Avatar
Default Re: Push in clutch to start car. (bac22)
steelevette,
if you really dont like that, go look at some 1990 300zx's I know htey dont need the clutch depressed to start. I have been in 3, and all 3 did not require that it be pressed.
Old 03-16-2004, 11:48 AM
VR'92
VR'92's Avatar
St. Jude Donor '03
Default Re: Push in clutch to start car. (94 M-6)
steelevette,
Thats kinda rude.?
I would suggest keeping the clutch thing but I would not suggest him get outta Corvettes. :confused:
[Modified by VictorRussell'92, 10:48 AM 3/16/2004]
Old 03-16-2004, 12:02 PM
jfb
jfb's Avatar
Jump the clutch safety switch. Then if you get stuck on the railroad tracks with a train coming, your starter motor can move you off the track.
Old 03-16-2004, 12:13 PM
Aaron71771
Aaron71771's Avatar
Default Re: Push in clutch to start car. (jfb)
I've started my car and drove away a few times when I have had clutch pedal related problems, just jump the switch.
Old 03-16-2004, 12:20 PM
snaketr
snaketr's Avatar
Steelvette, yes everybody did not read the question I think. The switch is somewhat adjustable or the rod could be bent. You should not have to push to clutch through the floor to start it. You want to keep the switch in place though so you do not accidently start your car in gear. You can adjust the switch so that the clutch is disengaged but not all the way to the floor so that is will allow you start the car. It is very difficult though to get to the switch, if you look at the clutch pedal housing, you will see it.
Old 03-16-2004, 01:47 PM
JasonL
JasonL's Avatar
Thanks. :)
Here, I highlighted the key term. It seems his clutch safety switch is maladjusted.
Old 03-16-2004, 03:55 PM
94 M-6
94 M-6's Avatar
Default Re: Push in clutch to start car. (VictorRussell'92)
quote:
VictorRussell'92
Thats kinda rude.?
I wasnt saying to go get a 300zx, i meant to go look at one and see what type of mechanism they use, thats all heheh
Old 03-16-2004, 04:28 PM
FX GS
FX GS's Avatar
Default Re: Push in clutch to start car. (Aaron71771)
:iagree: Jump the switch, its saved me a couple of times also.
Old 03-16-2004, 06:05 PM
Jloshotz
Jloshotz's Avatar
Can you put this in writing for me? LOL :lol:
Old 03-17-2004, 08:57 AM
Steelevette
Default Re: Push in clutch to start car. (Jloshotz)
Thanks for all the posts. I figured it out and it is now in a reasonable position. Where the metal rod attaches with a clip, can be bent and pushed togethor ever so slightly. I find the clutch pedal now at an acceptable level as the starter engages. Jeff :thumbs:
To Push in clutch to start car.
Quick Reply: Push in clutch to start car.
