Oil pan gasket
Oil pan gasket
I have a 1985 how hard is it to change the oil pan gasket with the engine in the car? Can you get to all the nuts? Can I use the one piece oil pan gasket that was on later years? Should RTV be used inaddition to gasket? thanks for your responses.
Re: Oil pan gasket (Hall1836)
If you end up having to remove the braces for clerance, use a back up wrench and a big 1/2" drive ratchet to remove the brace hardware. Those suckers in the front are on there tight. All can be done from under the car.
1. Use the 4 blue platic studs that come with the Fel-Pro gasket. They screw into the 4 bolt holes of the engine block. Then you position the gasket, press it up to the block, and the studs will snap over the gasket and hold it up against the block for you while you install the pan. Then you remove them after the pan is secured to the block with a few pan bolts. I had to cut 2 of those plastic studs in half to make them shorter to allow me to slide the front of the pan into place.
2. Use a light coat of contact cement on the upper surface of the gasket that meets the engine block surface. This will hold the gasket up against the block for you while you install the pan and bolts. Tighten the bolts in a left side, right side sequence. Then go all the way arround with your ratchet and check that no bolt is left loose. Wipe off all old oil leaks on and arround the pan gasket areas with degreaser and a rag.
Install a new oil drain plug, oil filter, and new motor oil and your set.
Start the car, look under for any leaks. For the next few days crawl under the car with a light and check for any leaks.
important
Make sure you clean the gasket surfaces at the oil pan and block before reassembly. This is critical to achieving a leak free installation.
If your 4 corner "studs" have a small male torx head like my 86 did, make sure your small socket is on it square and straight before you turn it. If not, you might end up stripping the torx head, then you will have some fun trying to remove them cause you have nothing to grab them by. One of those little regulat 1/4" deep sockets (can't remember the size) fits that male torx head perfectly. Just dont turn it till it's on the head square and straight. Take your time. If you screw any of these up, that pan ain't coming off till that stud does.
Goodl luck.
:thumbs:
[Modified by 86PACER, 5:14 PM 4/5/2004]
