max airflow for ported plenum, as&m runners, tpis big intake?
Re: max airflow for ported plenum, as&m runners, tpis big intake? (mos90)
No, it won't flow that much.
There are several sites of actual flow numbers for various setups. Check out the ThirdGen.org board and do a search for them.
I've got some of the links saved, so if you can't find what you're looking for let me know and I'll track them down in my "BookMarks".
Jake
Jake
The runners flow 218 CFM or so...they are the choke point.
To get around it, you can siamese the base about 2" and then each intake cycle can pull 2 runners worth of air.
Thirdgen has a pretty good coverage of everything you can do to a TPI motor. Check it out...
Re: max airflow for ported plenum, as&m runners, tpis big intake? (Joe90)
stock runners flow almost 210 so how can large tube as&mrunners flow only 218? asm says they will flow almost 260.
Vic
Re: max airflow for ported plenum, as&m runners, tpis big intake? (Vic'89)
Large Tube runners for the 1989 to 1992 Camaro, Firebird and Corvette. Have proven to increase torque by 30 ft/lb. and horsepower by 25 on stock 5.7L engine Flows 260 CFM per runner, Clear hard anodized finish, Includes gaskets and 4 bolts. Matches factory appearance, Polished runners are optional, please select polished when ordering.
taken form the as&m website....
St. Jude Donor '10
They flow 260.
The only LTRs that flow better are Extrude Honed Accel's. Here is what could be considered an independant test due to the fact they are trying to sell stealthram's here.
http://stealthram.com/flowcomparison.html
There's a site with the actual Dyno Jet numbers of a engine running a Hot Cam, 58 mm TB, heavily ported Edelbrock TPI base, large tube Arizona S&M runners and ported plenum compared directly to the same setup but with a MiniRam.
I forgot where the ariflow numbers are posted - I suppose I could find them if I look long enough - but the TPI setup listed above only made 272 HP @ 4800.
If that setup flowed 260 cfm, I'm sure the HP numbers would be substantially higher. 260 CFM supports over 500 HP.
Remember, it's what the parts flow when all bolted together, not what each individual part flows. Here's the link.
http://www.eecis.udel.edu/~davis/z28...MRwebpage.html
Cruise-In II Veteran
Here are some flow numbers from Dec, 1998 "Hot Rod" for intake & runners:
199cfm-stock
214cfm-Accel
217cfm-Accel, extrude honed
233cfm-Accel hi-flow manifold
243cfm-Accel hi-flow manifold, extrude honed
267cfm-Accel hi-flow manifold, extrude honed with Accel runners (not sure it these are siamese or not)
My understanding is that Accel and TPIS BM base are the same.
199cfm-stock
214cfm-Accel
