C5 Brake Upgrade - Help need spacers
I have a 93 C4 with the stock wheels and want to do the C5 Brake upgrade but can't find the spacers so that the wheels will fit over the
Does anyone have a source for a 1/2" wheel spacer so these brakes will work with the stock wheels?
:chevy
:chevy
1 Post
St. Jude Contributor
Re: C5 Brake Upgrade - Help need spacers (USRobo)
So you have "sawblades" right? The best source I've seen for spacers is MID AMERICA. $199 for a set of four, I know you only need two, but they come with a bag full of lug nuts and studs....... Try DRM, see if they'll sell you a pair...... Doesn't hurt to ask.
:cheers:
:cheers:
Re: C5 Brake Upgrade - Help need spacers (edsalinas)
Thanks, at that price the C5 upgrade compares to buying Baer Eradispeed even though I like the C5 setup better. :confused:
1 Post
Keep in mind you can gather the bits & pieces for the C5 stuff for under $500, most thru Superior Chevy as a forum member???
Here are the prices I come up with:
1 12530682 Reg C5 Caliper - RH $93.97 $93.97
1 12530683 Reg C5 Caliper - LH $93.97 $93.97
1 10445857 C5 Rotor - LH $55.83 $55.83
1 10445856 C5 Rotor - RH $55.83 $55.83
2 12455799 Caliper Brkt - 2 required $28.56 $57.12
4 12530697 Caliper Guide Pin (4 reqd.) $3.69 $14.76
4 12530703 Caliper Guide Pin Seals (4 reqd.) $3.16 $12.64
4 10139097 Brake Hose Gasket (Copper Washer - 2 per caliper) $0.39 $1.56
1 88909667 C5 Ceramic Durastop Pads $79.30 $79.30
Subtotal $464.98
C5 Upgrade brackets (Ebay) $120.00
Wheel Spacers (Ecklers) $199.00
Total $783.98
If you have A-Mold wheels it is much cheaper.
:smash:
Subtotal $464.98
Total $783.98
:smash:
I bought all the stuff for my C5 brake upgrade for $300 (not including the wheels which I was going to get anyways). If you look around and take your time, you can get killer deals.
1 Post
The price for new calipers shouldn't run more than $80 each, I repeat, shouldn't. Rotors from "rockauto" are under $20 each. If you buy "reybestos" pads, they come with the hardware kit & rubber boots. So what if you don't like the pads, you'll need new ones eventually anyway right?
Just passing info along bro...........
I got these prices from Superior Chevrolet. Most post that I read say they have the best prices.
Any place else I should check for better deals? :crazy:
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I got my C5 calipers and roters off C5 parts for sale...fella was insisting on moving up to Baer or something
Bought 4 wheels calipers and roters for $ 160.00
I still have the rears if anyone wants them :D
:seeya
:steering:
:seeya
:steering:
