Gauges
Gauges
I noticed that my digital reading for my engine coolant doesn't coincide with the analog reading of the engine coolant??? Which is the correct reading? :confused:
Re: Gauges (swoosh)
How far apart are your readings? Remember it's two different sensors. One is in the front of the intake below the water inlet and the other is in the cylinder head, so will probably read a bit hotter. I also don't think that any standard electronic resistance sender is highly accurate, so there's probably always something like a 5% variation possibility. :flag
