Code 34: Car won't stay running....Where to start???
Code 36: Car won't stay running....Where to start???
*EDIT* code is a 36 not a 34
The other day I went on a bit of a drive, and the SES light came on while I was driving home. I checked the code and got code 36. Now the car will start, but wont stay running when I let off the gas it dies instantly, and it wont idle. What steps should I take to begin to troubleshoot this issue?
Thanks in advance
[Modified by Wheelman, 9:07 AM 6/29/2004]
Thanks in advance
Re: Code 36: Car won't stay running....Where to start??? (Wheelman)
Code 36 is the high resolution signal from the opti. The car will run without the signal but the opti is well on its way out.....probably.
St. Jude Donor '10
Re: Code 36: Car won't stay running....Where to start??? (ittlfly)
His car doesn't have opti. Sounds like it could be the MAF to me. The exact same thing happened to my 85. Start it up and it died instantly. You can pick one up from Autozone for less than $100.
[Modified by SurfnSun, 10:41 AM 6/29/2004]
Re: Code 36: Car won't stay running....Where to start??? (SurfnSun)
It could be the MAF, as SurfnSun said. According to my manual (for an 87), code 36 indicates a problem with the MAF Burn-off circuit... it could be the relay... try to do some diagnosis before jumping out to buy a new MAF.
In my case, it didn't set a code, but the same symptoms were caused by a bad Idle Air Control valve.
Best of luck
Best of luck
Here's a link I found when I had (still have) my code 33.
I'm pretty certain my problem is with the MAF and I need to replace it.
http://www.c4vettes.com/ecm.htm#33
Re: Code 36: Car won't stay running....Where to start??? (TheStef)
By the way I don't know how accurate this list is because according to the service manual, a code 33 (for my car) only indicates an electronical problem and electronical trouble shooting with the Maf an burn of relays, it does not indicate anything about a "vacum leek" as incidated in this list.
Good luck!
I'm still searching for a used MAF, if any one has one, please let me know
Good luck!
Try replacing both relays ($10 each @ autozone) first...
Ron
I also have a used MAF, since replacing it didn't solve my idle problem, it should be in fine working order. I'll be "offline" for the next week, though.
Location: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
On the 89 a code 36 is "Mass Air Flow Burn Off Circuit ". I'd try replacing the MAF relays with new and see if that helps. There was a TSB for this in 88 and 89 models.
This helped me solve a code 33 (MAF) issue on my 88. and a 36 on a friend's 89.
Service Bulletin Number: 89-327-6D
Bulletin Sequence Number: 133
Date of Bulletin: 9105
NHTSA Item Number: SB028295
Make: CHEVROLET
Model: CORVETTE
Year: 1988
Component: FUEL:FUEL INJECTION SYSTEM
Summary: INTERMITTENT NO START, LONG CRANK, STALL, OR ENGINE SURGE-BOTH MAF RELAYS(BURN O FF AND BURN OFF CONTROL)SHOULD BE REPLACED-1988/89 CORVETTE DG
The original relays were found to not conduct enough power for the MAF burnoff action to complete. The GM TSB recommendation was to replace the original relays with new GM part #14089936 relays. Even if you have done the original relay replacement, the burn off relay may have gone bad. NAPA can get you 2 new matching relays for less than the dealer (about $11 each) if you give them the GM part #.
The 2 MAF relays on the 89 are mounted on the fire wall in the area under the battery. They should both be #14089936 or compatible replacements. You can try swapping one for the other and seeing if the code 36 is fixed or replaced with a 33 or 34. If swapping the relays stops the code 36 but gives you a 33 or 34, then the burn-off relay was definately bad. You need to disconnect power to the ECM for at least 30 seonds to clear the code.
Make: CHEVROLET
Model: CORVETTE
Year: 1988
St. Jude Donor '10
Re: Code 36: Car won't stay running....Where to start??? (Insane1)
I too had an idle problem on my '88 IROC. It was the IAC. Water leaked in an corroded everything.
[Modified by SurfnSun, 1:04 AM 7/1/2004]
Cruise-In II Veteran
Remove the air filter assembly so you can view into the MAF with a mirror. Have someone shut off the engine as you observe the sensor wires. If they don't glow bright red for 2 sec. after shut off, replace the burn off relay.
If you suspect a bad MAF you can sub one from a 3rd gen. F-body or Vette from '86-'89.
[SNIP]I'm still searching for a used MAF, if any one has one, please let me know [/SNIP]
Have you tried the wrecking yards? Take your old one with you and see if you can find one on an 'F' body.
I got mine that way for $50
Jake
Jake
