dumb to swap headers to pass smog test?
Hear is what may be a dumb idea. Calif. has gone over the deep end on smog tests, so I can't even think of long tube headers on my car unless...I put them on (say the ones from TPIS) after passing smog, put the old ones back on two years later to pass and then put the long tubes on again.
Is this dumb, or is it a workable idea? And, what are the best 3.07 gears to replace my stock rear end?
You might be able to built two complete exhaust systems from the headers back. Get everything welded together so when it's time to switch you just unbolt, drop eveything out as a unit, and bolt the other unit in.
Originally Posted by nobodyunknown
In Mo. They dont look under the hood unless you fail.
Yeah, my car just passed with long tubes and bullet cats.
If anyone has found CARB approved headers for an '89 Vette, long or short, let me know. It would sure make this whole process simple.
And, thanks for the replys guys!
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If this were planned for when you build your exhaust system, it shouldn't be that big a deal. Just make a place in the system where it can be unbolted just beyond the headers and have legal parts set up to bolt back in. No need to change entire systems. And I'm with you Strick, we other 49 should secede from California.....
1 Post
Originally Posted by Strick
This is what I'd do. Have a OEM complete exhaust and just swap. You'll be the most proficient exhaust man in the C4s. I think California should become their own country.
What's sick is that a properly tuned (and maybe even poorly tuned) car with LTs and bullets could pass the CA smog with flying colors, yet some early 80s P.O.S. Datsun will just bearly squeak by the upper limit, smoking and sputtering all along, and yet he gets to drive while the Vette doesn't.
I could not agree more with Perfusion. Get this, when I first moved back to Cal, my Vette passed the analyser part of the "SMOG" without a problem. That was with long tube headers, no EGR, no AIR pump, no pre-cats, and 140k on the odometer. A properly tuned Vette will pass just fine. The thing is to have a good main cat in the exhaust and a good tuned Vette. Of course, it would not pass "visual inspection" hence the biannual header swap. I feel that only what comes out of the tailpipe should matter. Unfortunately others do not see it that way.
Do you happen to know which shorties have CARB approval?
JBA Headers (Summit Racing PN#JBA-1815) makes a 50 state legal set for LT1 Vettes 91-96, so does Hooker. Seeing how you have a 89 TPI Vette, it might be hard to find a set for that. I have not been able to find a set for TPI Vettes anywhere. (If someone has please chime in) I could not find a set for my 86 anywhere online when I was in the market for an exhaust, that is the reason why I went long tubes in the first place. They are somewhat pricey and many guys feel that their HP gain is just not worth the expense. Some folks have claimed that shorties are more of a performance manifold that headers. It's kinda a tough predicament since you live in Cal and want a better exhaust at the same time. That is why I swap, since I have the time, the tools, and the willingness to do it. Long tubes was my only choice. Sadly there are no long tubes with a CARB or E.O. number, and there seems to be little if any shorties for TPI Vettes that I am aware of. That is the price we pay here in Cal for the sunny weather it seems. But there are ways arround it, you just have to get your hands dirty every two years. Some folk are fortunate enough to personally know a SMOG tech that will check off the visual inspection.
At least us Cal guys still have the 50 state legal Accel Super Ram to turn to for an intake. Good luck.
Location: The last place on earth to get cable... Sacramento
I have done it myself for more than one car out here... and for more than 20 years... I have a shelf of parts to "reinstall" when bi-annuals come due.
I have not set up my vette for this yet... but I have done it to numerous other sporty rides I've owned.
And the shorty headers are hard to come by... (approved number = JBA 1810) and give NO performance improvement... that may be why they got approved...
Having suffered in California for several years, it is definitely a different place to deal with. I went through months of searching for a set of LT Headers for my 90 to no avail. After getting a reply back from the CARB, it isn't a matter of there not being any that will pass, but rather a matter of none being submitted for testing. If none of the manufactures think there are enough cars out there that would buy them, then we are left high and dry. There is no limitation saying that a private owner can't make his own custom headers and then submit them directly to the CARB for testing, but who has enough time and energy to go through the trouble?
Since the test is no longer performed at idle, but rather throughout the RPM band, they should go back to a tail pipe sniffer and call it good. If you can build a C4 running a 502 BB that will pass the sniffer test good for you, who cares what is under the hood. It's what comes out the tail pipe at speed that matters right?
Of course this is just my humble opinion.
Dave
Dave
