Adjusting the spark advance table.
Old 08-03-2004, 10:50 PM
MrNuke
MrNuke's Avatar
Default Adjusting the spark advance table.
I am curious.
I've been messing with the timing tables on my '85 vette since I starte dburnign chips for it, and made some good improvements by changing the stock minimal timing table.
I checked out some friends' custom chips and I've noticed they always leave the timing table totally stock. How come? There is quite a difference I have tested between stock timing table and modified timing maps.
Old 08-04-2004, 06:08 AM
silver84
silver84's Avatar
Nuke, please post, before and after tables.
And your comments about what changed.
Old 08-04-2004, 10:26 PM
MrNuke
MrNuke's Avatar
That's just one table I'm using as an example. I have seen many bins that use the stock GM timing table. I am just wondering, why people don't seem to dwelve into it?
The table I am using is noticeably better in the mid and upper when I compared 2 chips using only the two tables in the car.
Old 08-04-2004, 10:35 PM
J Z06
J Z06's Avatar
I wonder if Mr. ski_dwn_it will chime in here.
He seems to be "MR CHIP"
How'd things make out today Gabe? Sorry for the rush. We we're swamped after I dropped you off.
Old 08-05-2004, 10:42 AM
lead foot 85 vet
lead foot 85 vet's Avatar
I hate those graphs....can't read them.......do you have it in table form?
Old 08-05-2004, 03:06 PM
MrNuke
MrNuke's Avatar
I'm not tryig to get into specifics, just wondering why it seems that the spark table is overlooked when making custom chips..
Old 08-05-2004, 04:01 PM
lead foot 85 vet
Thats a good question ....I made a post about a month ago asking if any one knew where the full timing should come in under differrant conitions and such and didn't get a single reply........I've asked around here locally and got nothing........nobody knows a thing about changing the timing map..........the drag race boys bring in full advance at what ever there stall speed is ............the tunning book I have says bring it in until it knocks, but I can't hear my engine and I'm not sure my knock senser is working because I never see any counts.........I wanted to see yours just to compare.
Old 08-05-2004, 05:16 PM
MrNuke
MrNuke's Avatar
Ohh .. gotcha..
Well my compression is only around 10:1, slightly under even, and with this chip, if it is above 80F it pings, at 60-70F car goes liek a raped ape.
Here is my table. Don't forget, it has to be cool out, my initial timing is set at 4Degrees, and make sure you haev good gas. I even add a can of Outlaw O2 booster to my 1/4 tank before racing.
20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0
28.1 28.1 28.1 28.1 28.1 25.7 23.9 23.9 23.9 23.9 23.9 23.9
29.9 29.9 29.9 29.9 29.9 27.4 26.4 26.0 26.0 26.0 26.0 26.0
35.9 35.9 35.9 35.9 35.2 33.8 32.0 28.1 28.1 28.1 28.1 28.1
39.4 39.4 39.4 39.4 39.4 33.8 32.0 29.9 29.9 29.9 29.9 29.9
43.2 43.2 43.2 43.2 43.2 43.2 40.4 35.9 32.0 32.0 32.0 32.0
43.9 43.9 43.9 43.9 43.9 43.9 41.1 39.0 35.9 34.1 34.1 34.1
45.0 45.0 45.0 45.0 44.6 44.3 42.2 40.1 38.3 35.9 35.9 35.9
46.1 46.1 46.1 46.1 45.4 45.0 43.9 42.9 41.8 40.4 39.0 38.3
47.8 47.8 47.8 47.8 46.1 45.4 44.3 43.2 41.8 40.8 40.4 39.7
47.8 47.8 47.8 47.8 46.4 45.4 44.6 42.9 41.5 41.5 41.1 40.8
47.8 47.8 47.8 48.2 46.1 45.4 44.3 42.2 41.1 41.1 41.1 41.1
47.8 47.8 47.8 48.2 46.1 44.6 43.6 42.2 41.1 41.1 41.1 41.1
47.8 47.8 47.8 47.8 46.1 43.6 42.2 41.5 41.1 41.1 41.1 41.1
47.5 47.5 47.5 47.1 46.1 42.5 41.1 41.1 41.1 41.1 41.1 41.1
Old 08-05-2004, 06:09 PM
lead foot 85 vet
Thanks Gabe............no way in hell I can go that far advanced, but interesting that you can.
Old 08-05-2004, 07:52 PM
MrNuke
MrNuke's Avatar
The reason I can is that I lowered the initial timing form 8degrees to 4, so in essence I am hitting 37.x degrees max at higher rpms, which in cold and dry weather works great with the 94-95 octance I run, otherwise when it's hot out I have to run another chip with less timing.. But this one makes a noticable difference on t
eh butt-o-meter,
Old 08-07-2004, 02:08 AM
gbody5
gbody5's Avatar
Help me understand. Did you mechanically set your base timing to 4 degrees or just change that in the chip, or both? If only in the chip, then wouldn't the ECM just add more timing across the board to get at your values set in the timing table?
Old 08-08-2004, 07:56 PM
MrNuke
MrNuke's Avatar
I just made the mechanical timing to 4degrees.
The chip still thinks it is at 6 degrees, so in addition it is pullign 2 extra degrees out of the total from there.
(More liek if my initial would be at 2degrees, not 4)
The reason I've done this was that during tuning the car and testign new chips and changes, I found this mapping to work best all-around, and wanted to keep it, but as I am changing A/F mixtures and new mods, I can just lower the timing with one stroke, instead of lowering the whole table..
Old 08-09-2004, 10:33 AM
scorp508
scorp508's Avatar
To clear this up, look at his timing table and -2 from the whole thing for total timing numbers.
Old 08-09-2004, 01:45 PM
Ramanstud
Ramanstud's Avatar
or Nuke could just keep the stock mechanical 6 degrees advanced, and change the ECM setting of initial advance to... 8 degrees, etc etc to trick the computer. Whatever works, so long as the total advance is where you want it to be.
Old 08-09-2004, 09:56 PM
MrNuke
MrNuke's Avatar
Actually that would defeat the whole purpose of making easy changes. If i did it that way I'd still have to burn a new chip every change I make. Might aswell adjust the whole timing table then..
Nah I chose to do it this way, so i can increase or reduce my overall timing but not have to burn a chip every time, and keep the well-working table runnign in the car. Once everythign is final I can burn a chip with an adjusted spark table that I can set at the normal 6degree mechanical advance.
Old 08-09-2004, 11:06 PM
scorp508
scorp508's Avatar
Hmmmm... I can flash a new chip faster than manually readjusting my timing. In fact the last time out that is exactly what I did. I kept changing the base timing in the chip between runs.
Old 08-09-2004, 11:26 PM
MrNuke
MrNuke's Avatar
Unfortunately on an '85 it doesn't work that fast..
Maybe once my ecm burns out I may switch to a '165 ecm, but meanwhile I am stuck using the 2732 eproms and UV eraser and
willem burner to do my chips..
Old 08-10-2004, 10:27 AM
scorp508
scorp508's Avatar
..... but meanwhile I am stuck using the 2732 eproms and UV eraser and willem burner to do my chips..
Damn, I feel your pain. Make the switch!!
Old 08-10-2004, 05:42 PM
MrNuke
MrNuke's Avatar
Hehhe. Right after I get my 11, I will start on a few smaller projects..
To Adjusting the spark advance table.
Quick Reply: Adjusting the spark advance table.
