What spark plug for hot cam or other engine mods
Old 08-05-2004, 07:47 AM
LT4BUD
LT4BUD's Avatar
Default What spark plug for hot cam or other engine mods
So you do cam, head job, headers, maybe some other mods....
thinner head gaskets..
Does the stock spark plug, or oem specified equal, still work fine? Or do you go one or two stages colder????
This question is a little bit which brand, but mostly directed toward what heat range.....or style works best...
BTW I went with Denso Iridium IT20 which is one stage colder than Denso's specified IT16 for stock. I have unconfirmed reasons to believe either I should have gone to colder range or some other style..
Help....plugs are too hard to change to go experimenting...Denso's are also big $$$
Old 08-05-2004, 07:59 AM
hngacurv
hngacurv's Avatar
I use NGKs.
Old 08-05-2004, 08:34 AM
Nathan Plemons
Nathan Plemons's Avatar
I just use AC Delco R44LTS plugs. Eventually if you go through enough tables you'll find that this is the non platinum equivelent of what is supposed to be in the car in the first place.
Old 08-05-2004, 09:01 AM
LT4POWR
LT4POWR's Avatar
I've tried a few different brands/heat ranges, and I like the NGK TR55 the best.
Old 08-06-2004, 10:29 PM
STEVEN13
STEVEN13's Avatar
[QUOTE=Nathan Plemons]I just use AC Delco R44LTS plugs.
Nathan,
I purchased these R44LTS and they are to big for the heads on my 1992. Can this be right.
Thanks,
Steven
Old 08-06-2004, 11:58 PM
Nathan Plemons
Huh? I've put these in the last 4 LT1's I've worked on. I've got a set right in front of me to verify the model number.
What is too large? The threads? They had to have given you the wrong plug.
Old 08-07-2004, 08:10 AM
STL94LT1
STL94LT1's Avatar
Default Denso IT20
These are the plugs I run with my heads/cam LT1, and the car runs great.
Old 08-07-2004, 08:54 AM
STEVEN13
STEVEN13's Avatar
Nathan, STL94LT1
Thanks for your replies.
The threads are larger on these plugs than the Bosch I took out.
Also when Autozone cross referenced the part# (on the R44LTS)it came up with a different Bosch plug part# than the plugs I have in it.
Could the plugs be stamped with the wrong part# ? Or am I losing my mind
I am going to put a new set of Bosch plugs back in.
Thanks again,
Steven
Old 08-07-2004, 10:28 AM
LT4BUD
LT4BUD's Avatar
Thanks for the response.......
When you say the car runs great, do you mean WOT performance or low speed cruising.......??
My problem occurs at "low" speed cruising after the engine has been run for while.....seems I get some missing and an occasional serious detonation when trying to cruise say around 1500 rpm....no problems observed if I keep revs up, say above around 1800....
I am thinking that after a while the plugs might get too hot causing the detonation...I have also observed knock retard when I start to accelerate...maybe as simple as "bad" gas....
Old 08-07-2004, 11:36 AM
STL94LT1
STL94LT1's Avatar
Default Smoooooth Cruising
'BUD,
compared to the stock plugs, my car runs smoother from idle to WOT with the Densos.
Also, I'm running 11:1 compression and 41* total timing at WOT, with 0 detonation.
Old 08-07-2004, 09:34 PM
STEVEN13
STEVEN13's Avatar
Those plug are the right ones! I am so stupid.
This is what happened: The first plug I put in did not feel right so when I took it out (apparently there was) a heli core that came out with it on. What I did next was go to a easy one to put in. So now like a idiot I am trying to get this same plug with the heli core on it to the other spark plug holes.
Thanks,
Steven
P.S. I am not sure if its called a heli core
Old 08-08-2004, 09:25 AM
rrubel
Support Corvetteforum!
rrubel's Avatar
Heli COIL... somebody stripped one of your spark plug holes and had to have it re-drilled. Downside of aluminum heads; probably tried to change plugs with the engine hot.
[RICHR]
To What spark plug for hot cam or other engine mods
Quick Reply: What spark plug for hot cam or other engine mods
