85 maf sensor troubleshooting help
i need some help on trouble shooting my maf sensor , wiring for it and burn-off module..car is throwing code and we put in a known good maf sensor..car runs great when no s.e.s. on then next thing you know s.e.s. is on and car runs like a miss, rough,lack of power ... please help!!!
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Turned out to be the IAC moter which rarely shows up as a code and is rarely discussed in GM/Helms
Replaced it and everything is fine
seeya
Received 1,401 Likes
My only guess is a bad burnoff module, unless you can track down a short in the MAF wiring.
Also Looking For The Burn Off Module..got One?
Try GMPARTSDIRECT.COM
Jake
Yes its behind the dash on the passenger side.
Remove the front rubber hose from the MAF sensor so you can look in it, ignition on, ground the ALDL terminal E, shut the ignition off, quickly observe the hot wire in the MAF sensor, it should glow red. Easier if you have a helper, as you have to do this quickly or you'll miss the wire heating up.
The module was also used in F body GM vehicles with the port injection on the 305s. hope this helps.
I also sudenly developed a code34 in my 85.
I read if you clear the code34 and run the car without the maf connected and you get a code 33 it is a bad maf.
if you still get a code34 it is wiring or processor.
I have yet to try it but it may help.
