service ABS service ASR Light
This morning my service ASR AND ABS light stayed on while driving and sometime u can hear the asr whining from behind the drivers seat.
Has any on experienced this and what was the fix.
1992 6spd. LT1
1992 6spd. LT1
The noise you hear is the ABS unit. Did you recently do a brake fluid flush?? You may have some air in the ABS unit. Also check the fluid level in the master cylinder resevoir. With the ABS/ARS lights on, the ABS/ASR units will be inoperative but the brakes will still work.
The ABS unit requires a Tech-1 with a brake module or similar scanner to perform tests or pull codes on the ABS unit. The unit is fairly expensive so you should have the problem looked at by a competent shop that has the proper test equipment.
I have had no work done recently to brakes,I checked the fluid level but I will check again.The car sat about 1 month in the garage and when I went to take her out this happend.
The ABS unit does a self-test when the engine is started and the car first moves forward at about 3-4MPH and you can easily hear the ABS unit cycling. After that, it should remain quiet. If it's still running, it may be going bad. In any event, the CCM will have a code set that needs to be pulled but that requires the scanner.
With my 92, I have had my ASR/ABS lights flash on and off after extreme braking and I found out that the fluid in the master cylinder resevoir must be right at or very close to the full mark to keep the lights from coming on. Even a 1/4" drop in the level can cause the lights to flash on the DIC. They should not stay on though.
Same with my 1992 on a road course.
Steven
That's where I noticed the ABS/ASR lights coming on!! When I topped off the reservoir to the full mark, I didn't have any other occurances that day.
Apparently, enough braking force will cause the fluid to slosh around and trip the sensor in the reservoir.
