1992 LT-1 rough idle, pinging/knocking
Old 07-17-2001, 09:29 AM
dsky
dsky's Avatar
Engine starts fine – strong. then rough idle.
When in drive, I get rough idle, almost stalling to 1200rpm.
(remove IAC valve connector, runs smooth,
but high rpm's)
reconnect IAC valve,then when driving,
Acceleration I get pinging/knocking, greater with more throttle.
When running steady 50mph, I get stumbling, hesitation
When coasting, it’s almost bucking!
Replaced opti-spark, plugs, wires and water pump.
Tested fuel pressure 42lbs before engine start, 39 when running at idle.
all injectors drop engine speed about 50rpm when disconnected.
cleared fault codes, and nothiing new shows up.
Question: WHAT HAVE I MISSED??????
Old 07-17-2001, 09:47 AM
nobodyunknown
nobodyunknown's Avatar
Sounds like a O2 sensor.Check your book you may have more than 1.
Also could be dirty fuel & or air filters.
Old 07-17-2001, 09:59 AM
Goody
Goody's Avatar
You need to hook up a code scanner to see what the engine is doing. Also take another look at your spark plugs. See if the engine is running lean (possible clogged fuel filter). What is the reading from the throttle position sensor?
Old 07-17-2001, 10:17 AM
Nathan Plemons
Nathan Plemons's Avatar
You say it idles high but smooth without the IAC. Can you drive a car without the IAC connected??? If you can, try unhooking it and see if your problems go away.
Old 07-17-2001, 12:27 PM
YLO Z06
YLO Z06's Avatar
2023 C5 of the Year Finalist - Modified
Some possible culprits:
- Faulty IAC valve
- Bad EGR valve
- Spark plugs not fully seated in head
- Plug wires not on Opti in correct order
- Carbon-coated 02 sensors (Mine has 3)
- Clogged fuel filter
Old 07-21-2001, 02:56 PM
LouisBarton
LouisBarton's Avatar
How about squirting some Throttle body cleaner in the IAC's air passage hole with the engine off and the IAC removed? If it got better with the max air bypass (IAC removed),maybe you've got a varnish problem in the air bypass circuit of the throttle body. If you remove the IAC's electrical connection with the motor running you have to reset the ECM after reconnection via a procedure described in the official service manual.
Old 07-21-2001, 09:16 PM
95BLKVette
95BLKVette's Avatar
Highly Recommend Check for codes first, as other Forum Member Suggested, then proceed with troubleshooting.
Old 07-21-2001, 11:21 PM
Lloyd Smale
Lloyd Smale's Avatar
sounds like your lean change your filter if you havent allready! then I would olm check your injectors and check your fuel pressure
To 1992 LT-1 rough idle, pinging/knocking
Quick Reply: 1992 LT-1 rough idle, pinging/knocking
