My winter project....what would you do? or are you doing?
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
Ok so my L-98 I know has 1 bad fuel injector...so for my winter/early spring project Iam going to replace fuel injectors....what else do you think I should do? Iam basically looking to do mods that are going to up the horsepower/torque the best without hurting the remaining reliability of my 131,000 mile mostly stock except for exhaust and bolt-ons motor. I should have about $1,000 to spend and am not really interested into dipping too far into my motor since it has so many miles on it already.
So to recap everything...here's what Iam thinking of doing:
1. SuperRam runners and plenum....(I can't afford a new manifold and don't want to beef up the top end too much.)
2. New fuel injectors (taking recommendations....thinking maybe, 22 or 24 lb Ford SVO's?)
Should I upgrade the stock Cap, Rotor, and Coil to maybe Accel's SuperCoil, HEI performance Distributor Module?
thanks
jeff
thanks
jeff
If your cap/rotor/wires/etc. are in good shape, you won't benefit from that stuff much, at least that's my opinion...
I plan on porting/polishing the stock plenum and adding high flow runners this winter, that may be enough for your setup, depending on what your other mods are.
My big winter project involves LT headers and a true dual exhaust for my L98
Cruise-In II Veteran
You might send your injectors to Rich at Cruzin Performance, unless you have one that failed the resistance check. Rich can not only recondition & flow test the set but also match them for a slight cost adder.
Unless you plan on spinning your modified L98 close to 6k RPM I wouldn't bother with an ignition upgrade. If you do go that route consider the HyperTech setup for an easy bolt on that is good for that range.
I have no performance mods in mind but need to get some new brake pads on the rear soon, ie before the snow falls again in SE NY.
My clutch is shot, thats my winter project and rear main seal looks like it might be leaking
I don't think there is much benefit from the accel cap/coil. But if yours is needing replacing a good tune up never hurts!
NCM Bash 2008-2018
yep it failed...
yeh, so that injector did indeed fail the resistance test. Only 8.9 ohms.
Gonna go new.
After hearing the recommendations, gonna stay away from altering my ignition for now. I don't intend on being in the 6,000 rpm range too long.
Maybe after the superram upgrade my L-98 might get closer to live up there, but definitely won't be in that range for long.
keep comments coming
Gonna go new.
NCM Bash 2008-2018
well i know anything can happen....but.....
Originally Posted by chriswtx
Save your $$$ for a rebuild. My L98 spun a rod bearing at 120,000miles.
Well i know that anything can happen...yours went at 120,000 but I know many a L-98 that go past 200,000 strong plus can't I use the superram on the L-98 after it gets rebuilt? plus...I think the superram can pretty much go on anything SBC from 350 to 383 or maybe bigger?...correct me if Iam wrong
With as stock as that set up is, the only thing you can gain from altering the injector size, is the burden of tuning the chip to get the A/F ratio back to what it is now. Have them cleaned and flow matched or buy new stockers.
RACE ON!!!
Your profile says you've got a 1990, so you've got the Multec injectors that tend to have coil problems (I think I read in 1993 or therabouts they changed the Multec injectors to eliminate this problem). I've got an '89, and only 3 injectors were still above 16 ohms, so you're doing better than I was!
I went with the 22# pink top Bosch injectors from Five-O, they're working great for me other than the car starts a bit harder now. The car ran through the IL emmisions test a few weeks ago with flying colors (ran the IM240 test on the dyno, the numbers were good enough during the first 30 seconds or so that they finished the test early).
It seems that about half the folks go with the 22# injectors and the other half go with the 24# ones. In either case the ECM can adjust the pulse width far enough so the car will run ducky in closed-loop mode. Since it sounds like you're going to be upgrading the engine some, I'll probably tend towards the 24# injectors.
In either case I'd get an AFPR so you can fine-tune your WOT and open loop air/fuel ratio.
Good luck!
Ben
Good luck!
Ben
Get a new set of stock equivelant injectors and save your money and freshen the motor up in a few years.
Ron
NCM Bash 2008-2018
altering the injector size?
Originally Posted by CFI-EFI
I disagree. It won't help THAT much.
RACE ON!!!
RACE ON!!!
From what I have read here on the forum the computer can compensate for the pulse widths and I can tune either up or down the fuel pressure to get it right with my AFPR which is installed already.
Just got the 2800 stall TC installed, and soon I'll get the Hotcam kit with the 1.6 RR's in, along with a new optispark and a new set of plugs and wires. Hoping to take a half-second off my quarter mile time.
Look for some posts from Wheelman in the last several months. He ended up adding the SVO injectors and had a lot of problems running it with the stock chip.
Ron
Received 1,401 Likes
well, my exhaust should be here by Xmas 2029
