LT1 valve cover gasket thickness
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I don't know but they're going to be the same compressed either way because the cover bolts seat when tightened to a pre-determined height. Not like an old stamped steel cover where you can gain height and clearance by using a thicker or double gaskets.
........good point :o .
Tom Piper
Are you getting ready to add RRs or something? I have a friend with a '92 running Crane Golds 1.6s with no clearance issues. I'm not sure if he removed the drip tabs or not. I have the later composite covers and have run aluminum 1.6 RRs and now have the Comp Cam Pro Mags. I did remove the tabs when I first installed the aluminum ones.
