Calling CAM timing EXPERTS!!
I have been trying to figure out what adv/retard i want to install my roller cam at. I've been fooling aroud with desktop dyno 2003 and noticed that 4-8* retard seemed to be optimum for my setup. I entered my EXACT engine data (head flow, cam card info, exhuast, etc.) to get a more accurate result. You really shouldn't go past 6* adv/retard with a cam either. For the cam i have, what should I install it at?? I'm lookin for 2500-6000 RPM range with the best numbers possible. I have a 3000 stall in the car as well so 3000-6000 is really where i'm wanting to put the numbers down. Here is the link to the cam card (some specs in my sig as well).
http://www.cranecams.com/index.php?s...31&lvl=2&prt=5
Your best bet there would be to talk to Crane. Most performance cams have some degree of advance ground into them already. If you tinkering with that you'll likely have a miserable performer.
The cam specs are similar although slightly larger than the hot cam. It's gonna scream in the 3000-7000 RPM range as it sits. I'd say just install it straight up and be done with it.
If I'm reading the cam card right
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 4.0 BTDC 38.0 ABDC 107 222.0 °
Exhaust 52.0 BBDC (2.0) BTDC 117 230.0 °
Means that it's already got 4 degrees of advance ground into it.
Well, i called Crane today and talked with the tech guys. They were recommending the same cam you guys were. We decided that with my near 11:1 compression ratio that I could retard the timing 4 degrees on install to compensate for the lower duration and prevent any detonation. The cam does have a 4* advance ground into it. This correlates with what the dyno program was suggesting too (maybe it will provide a decent guestimation after all :O)) Thanks again and I hope to get her built and get some dyno runs on it. I'm sure it will be quite nice!
