transmission conversion
7th Gear
Hey!
I am seeking information about converting a 1989 automatic C4 to a manual transmission. Are there any links available?
Besides the obvious hardware of clutch linkage, hardware, bellhousing, what else is required? Is steering column different with automatic lock vs. manual lock? Is engine management/computer need to be modified/changed?
Thanks!
Jamie
Thanks!
Jamie
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
My brother and I did this to a 67 Mustang and it was a huge PITA!!! I will never do it again. I will buy a manual car before I have to tackle that job again. I can't imagine that it is an easier task on a Corvette.
well their are alot of things!
the dana 36 may not hold up!
all manual cars were equiped with dana 44s becuase they can take more abuse!
If ne thing dont do this!
its near impossible and by the time you are done you could of cold your car and bought a new manual and still ahve $ for parts!
7th Gear
I want to do it because you say I shouldn't
I converted my 1977 Trans Am Bandit Edition with a 400 Pontiac engine from Turbo 350 to Muncie M21. I used all the correct parts, did my research, and completed the task. It was a conversion to be proud of, even with the hard-to-find manual column lock and manual console. I would do it again.
I will probably use 86-88 bellhousing for 4+3 so I can use the Richmond 6 speed with custom gears.
It is hard to find a cherry C4 in bright red with black leather interior with a manual transmission without an exuberant asking price. I can haggle all day for automatic cars that are plentiful, put in a custom transmission and change the Dana 36 to Dana 40 with my choice of ring and pinion.
well then you are god my friend
and more power to you
I know that MTI racing did a c5 conversion if that helps conctact them REESE *** is a freaking genius!
also try www.moreperformanceinc.com
they are very knowlegable
hope this can help
also did you consider buying an manual and repainting it...
your friend
Sean
happy new years!
hope this can help
your friend
Sean
happy new years!
Correct me if I'm wrong, but isn't there someone on this board in the processof doing one of these conversions? It has been a while back and I think he was using a ZF.......then again.....I have been wrong before :o
Perhaps you're talking about me or perhaps the guy that was installing a ROD-6. I have really only just begun the process however. I have the ZF and all the OEM parts (except a steering column). Right now I am working on getting my custom exhaust off the header collectors. The guy that made it really tighened the heck out of the clamps, putting detents in the exhaust pipe and header collector... It is not moving without some cutting.
Anyway, with good mechanical ability and some tools, this job is fairly straight forward. I don't understand why some people are just telling you to sell it and get an automatic car. The same philosophy could be applied to building up your motor. I am sure a C4 equiped with a 383 or larger could be had complete and cheaper than if you did it yourself, but then you would be buying someone else's creation.
My sig has a link to a pretty lame page I have started. It's really just a place holder for when the conversion really starts moving and I will put some more time into it. If I get the exhaust off tonight, I may go for broke and remove the trans this week yet and see what sorts of balancing issues I have with the flywheel I have.
Wow, am I actually reading this? Tons of people have done the swap. 700r4-> ZF Six Infact I think their are kits on ebay from time to time. I believe IBEAM??? is doing the ROD6 swap right now.
This is no new thing though. Good luck!
There are hundreds of red C4s with MT for sale right now. Probably very few of them are asking more than what you will pay for your car plus the conversion.
