L98 Head Bolts & Washers?
The stock head bolts on my 86 alum. heads have washers. The new set of Manley head bolts are shoulder bolts with no washers. Should I add washers or not? No washers = affect on torque readings?
Defintely use washers so as not to gall the Al head with the bolts as they get torqued down.
btw, for anyone reading, don't re-use factory head bolts as they are torque to yield. They've stretched.
ARP
ARP
Received 3,043 Likes
St. Jude Donor '05
Originally Posted by geezel
Late 86 with aluminum heads. I'm actually installing a new set of AFR/TPIS heads now.
Originally Posted by CFI-EFI
On an '86???
RACE ON!!!
RACE ON!!!
However, on Aluminum heads as far as I am concerned, you need to use washers on the bolts to prevent the harder steel bolt galling (cutting into for want of a better description) the softer aluminum head when tightening/torquing down.
Check the application list for your new bolts, if they dont have washers, they may be meant for cast iron heads only.
Cruise-In V Veteran
"Shoulder" bolt is the wrong term. They have a flange that is formed as part of the hex head which may act as the washer.
Originally Posted by Davemc1963-87conv
I think CFI-EFI means that on an 86 the bolts if original would not have been torque to yield fasteners and can be reused.
Even with a flange headed bolt, I would use a washer if the bolts are long enough.
RACE ON!!!
I have built my own engines since I was 17 years old but had never came across "torque to yield" head bolts before my 85 L98. I knew the small block torque spec and sequence by heart so I just went ahead and started tightening the head bolts down. As luck would have it I snapped off the last one to be tightened. I was highly miffed so I went and bought a whole new set, this is when I learned about "torque to yield". Sure wish I had new it a couple hours earlier. Anyway, do NOT re-use any headbolts and I agree with CFI-EFI, use washers if length permits. The shoulder of the bolt is still going to gall the aluminum.
Originally Posted by VetNutJim
Where to get HARDENED WASHERS guys?
Don't use standard soft ones.
