Open door chime
Open door chime
When I have my door open and the Key in the ignition the chime sound intermitently works. Does anyone know where this chime is located excactly under the dash? What do I need to take off? How much does it cost? Thanks
Elite Torch Red Member
After talking with Gordon Killebrew about this(there were three of us in a row with the same problem). He said just give a whack on the dash above the A/C vents and that usually will fix it. But if you want to check the relay, you'll have to remove the DIC I believe, the relay is located behind it. I never looked in the manual to verify the location.
