Custom exhaust... for real this time
I'll have pictures up later. But I got the work done today. LT4 resonator, and Dynomax 3" in, 2 1/2" dual outlet Ultraflow SS mufflers.
The work is excellent, it looks very stock and very nice. I'm very happy with the guy who did it. From lifting the car to the fabrication to painting the mufflers, he was very careful and thorough.
When we looked at the mufflers though, they were slightly different than the way they generally work. Instead of a 3" perforated pipe for a short distance that Y'd to dual smaller perforated pipes, it was a huge 3" perforated pipe for about 3/4 the length of the muffler. Then it was just an open chamber to the dual outlets. I guess that should have told me right there it would be loud. The muffler case is already pretty short, but 1/4 of it provides no muffling at all!
The car sounded great coming out of the shop, and not really very loud either. The volume of sound isn't really too much more than stock, you can still hear the mechanical sound of the engine prominently when getting on the gas.
But the resonance.... holy crap... I don't know if it's less or more than some other systems. You can cruise at 60mph in 5th no sweat, and 75+mph in 6th no sweat. But below 2,000 rpm you get more resonance as you open the throttle progressively from cruise level to cruise/slight acceleration. And around 1,500-1,700 rpm it is really jarring when you give it any throttle at all. Enough that my voice would vibrate slightly as I talked. My head was hurting a bit after an hour.
It's possible to drive with little resonance, but you need to be in the right gear to stay in the right rpms. You have to not mind driving at ~2,000 rpms vs shifting to a more relaxed cruise. Cruising with the windows cracked at 60 it doesn't seem too different than stock, there's just a slight burble where there'd ordinarily be more of a drone.
The overall volume level isn't too much higher than stock, it's just that the resonance peaks are much higher. It's not like that all the time, but when it is, geez!!
I'll see if they get quieter after a couple hundred miles, and see how they grow on me in more regular/short distance driving.
But if you want to try the same thing, I would not recommend 3" mufflers. If you use LT1-style tips maybe it would be ok as the muffling would extend the whole length of the muffler.
I will certainly consider changing them out to 2 1/2" in/out mufflers in the future, or maybe even some 50-series Flowmasters. I think if I do, I'd like to get the car dynoed first.
The sound is subjective, I loved the stock sound. This is deeper and burblier, and doesn't have as distinctive a sound over other pushrod 'vettes. IMO, the stock sounds of a ZR-1 and say an LT1 'vette were easily discernable. I'm not so sure my car now sounds any different from a pushrod 'vette with fiber packed mufflers. The sound is good, though, not a bad sound.
Originally Posted by 415LT5-badZR-1
No pics - therefore:
Here's the LT4 resonator compared to my 1990 (mine was a lot cleaner). Look how significantly the 1990 resonator tapers down! The LT4 seems to be about 2 1/2" through it while mine was about 2" through it. Both are perforated straight pipes inside with fiber packing around that:
Here is what the muffler looks like inside, you can see how it doesn't Y to the outlets:
Here it is all together. The mufflers were highly polished, so they got painted black. Not perfectly stock looking that way, but close enough for me:
Original vs modified:
Like I said, I'm very happy with how it looks. It's a spitting image for stock, except actually the tips are even more perfectly lined up now.
Some sound/video. The before (wasn't fast enough on the camera to get the car at start-up):
http://aurora40.dyndns.org/Hometown/...ust/before.MPG
The after:
http://aurora40.dyndns.org/Hometown/...aust/after.MPG
The after:
Bob-
Very nice work; I doubt my exhaust guy will cut and weld that good. I am installing Jeals and Random Tech cats and am going to try to use all stock pipe back of the cats ( 2 3/4") with the LT-4 resonator ( 2 1/2 ") and 2 1/2" Flowmaster mufflers. I hope it will produce something a little quieter that your set-up but still produce a decent exhaust system. BTW, anyone know a good exhaust guy in the Houston area ?
Greg.
Greg.
Originally Posted by JoeyGibson
love that license plate
Originally Posted by Sgreg
Bob-
Greg.
Greg.
Oh, also it was $520 for all the labor and the Dynomax's, and I paid $70 shipped for the resonator from a forum member. Seems like if you get the timing right, sometimes you can get stock exhaust stuff for free, though. So it was cheaper than buying and having installed any other exhaust option. Plus it looks stock (I know, no one cares...)
Looks nice and sounds even nicer!
You oughta post your sound clips to this post so they can all be collected together:
http://forums.corvetteforum.com/show....php?t=1425360
That setup looks great. Very much stock looking, but the sound is nasty.
I like the car, and plate too. Like my plate, (4CMLT5), to people who don't know, it doesn't look like a vanity plate. But to those who know what a ZR1 is, it sends the message.
BTW, have you read the article by Hib Halverson (on the ZR1 Net site) on the custom exhaust he pieced together? I haven't heard the results, but he claims a good increase in power, great sound, and minimal resonance. Check it out. It may give you some ideas about other muffler choices.
I've got headers, no cats, Xpipe, and 3" B&B's. So, let me tell you what REAL RESONANCE! is........
I just kept thinking if I went 2 1/2" I'd regret not trying 3", though I suppose if 2 1/2"s were on the edge of being too loud, I'd probably be glad I didn't go 3". And I kept thinking if I went Flowmasters, I'd regret not having straight-through.
Originally Posted by kmoudy
NOT TOO LOUD...damn..it scared the little dog here in my office..
you'll need to learn sign language in a few days..
one word..Corsa...but i love your plate
I'm warming up to it though. It sounds pretty good, my 30 minute drive to work today was fine, it didn't bother me. And the car definitely feels like it gained some power all over the band (though I haven't run it out to 7 grand yet). Even below 2,000 rpm it feels more responsive when I press the gas.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
I like the sound!!!!
Sweeeet sound Bob!
Looks like the stock/sleeper set up...I'm in that camp...stealth!
Nice growl at idle and plenty bark on the blip!
Sorry for the Q's:o
you re-used the stock tips?
The new mufflers were too shiney, so black'em out...right?
The resonator from the LT4 fits the stock pipes??? or you need new pipes?
Resonance seems to be 1500 to 1700 in 6th? less than 1500 rpms in 6 is where I cruise I think? Can't remember it's been so long that I haven't driven my car!
Maybe I try this but with flowmasters....I have no top end work like you do so it proly will not matter to my car...for sure like the sound!
to you on this job!!
Tom
Sorry for the Q's:o
Tom
Originally Posted by tomtom72
Sweeeet sound Bob!
Sorry for the Q's:o
Tom
Sorry for the Q's:o
Tom
Yes, those are the stock tips. They were cut off the original mufflers and welded on. The LT4 resonator is exactly the same dimensions, just with less pipe taper. It fit up perfectly.
I had to go with Dynomax mufflers to get the outlet spacing required in order to retain the stock tips (because I wanted straight-through mufflers, thus eliminating Flowmasters). They only come in aluminized cases or in highly polished stainless. So yeah, they were crazy shiny and would have looked very weird. So they got painted flat black for a more stock appearance.
If you use Flowmasters they would probably match up just fine without painting as they are a dull metal finish, not shiny. You might paint the end of it since that's how the OEM mufflers are.
If you don't use stock tips, or if your stock tips are the LT1 style, then the muffler choices really open up to you. The LT1's just require a center outlet, no spacing to deal with, and non-stock tips, you don't have to retain the stock spacing in which case some Magnaflows or something would work too.
The resonance really was killing me on the way home from the shop, though it was about 65 miles from me. Since then it hasn't bothered me too much, though it is certainly more than stock. I would guess with some smaller mufflers it would be better, though. Really, the resonator is 2.5", so I don't imagine having 2.5" mufflers would hurt much.
Originally Posted by cadillac531
Bob:
It sounds BOSS!!!! I love the fact that it looks stock, yet sounds like it's ready to feast on some poor unsuspecting ricer.
Constantine
Constantine
Tips...
Thanks Bob for the info.
I was liking to keep the 90 tips on my 90. The more I looked at what was out there in Corsa & Borla & B & B, I was liking the 90 tips even more as all the other tips from the big dogs didn't hit me right....I guess I'm the wierd one but I like the way the stock 90 tips look. The only other tips I really like were from I guess the LT1's and the LT4's. They are the single large rectanglular ones that fill the whole bumper cut out....but I figured I shouldn't put those on a ZR-1 until I think I saw them on some late mod ZR-1's and I really liked the look. Did the 94-95 Z's have single sq tips??
The resonance would kill me as mostly my rides are loooong.
Maybe I get away with the LT1/4 tips and use your idea for the LT4 resonator and any 2 1/2 " single outlet muffler like flowmaster or some other generic brand.
Thanks for the R & D
Tom
Tom
Hey Tom, I believe ZR-1's from 1992 and up had the single rectangular tip. So if you like that, it would be easy to find mufflers like that. However, the Dynomax's I used also come in a 2 1/2" inlet size, and there are some Flowmasters that would probably work in that size with dual outlets.
Here are a few more comparable sound clips. I tried to take them in the exact same parking lot, but there was a church service going on, so what can you do... It also seemed there was a bit of wind noise the camera was picking up. It wasn't noticeable at the time, though, and wasn't a windy morning.
Accelerating away
Stock: http://members.aol.com/corvettezr119.../accelrear.mpg
Modded: http://members.aol.com/corvettezr119.../accelrear.mpg
Peeling out
Stock: http://members.aol.com/corvettezr119...ps/peelout.mpg
Modded: http://members.aol.com/corvettezr119...st/peelout.mpg
Accelerating away
Peeling out
Sweet!
The sound on your car is soooo choice!
Yea I thought that the later model Z's used the single tips. I like that look...kind of reminds me of my 72 LT-1 after I put the stock sys back in....the side pipe covers were getting too expensive
Also, FWIW, my wife didn't seem to think it was too loud at all in the car. I really thought it would bother her. Though she also said she always thought the car was loud. I guess it would help to hear what some other cars sound like inside and out.
