C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Noise from Clutch
Old 03-14-2007, 04:08 PM
Bmarcum
Bmarcum's Avatar
Default Noise from Clutch
My car started making a intermittent noise when the clutch is in. Anyone had this problem? My slave cylinder is leaking a little and I am replacing it, but someone said it may be the two piece clutch. Any tests? Thoughts? The noise goes away as soon as you let the clutch out. It is a bad noise! Thoughts. Thanks
Old 03-14-2007, 04:20 PM
Crabs
Crabs's Avatar
My educated armchair diagnosis would be a bad throwout bearing.
It's a loud squeal like noise, right?
How many miles on the car?
ZR1's don't have a two piece clutch. Just a standard clutch disk and a pressure plate.
It does have a dual mass flywheel, maybe that's what you're referring to.
They do fail, but the failure mode usually produces a knocking sound.
TomC
'90ZR1 #792
Honorary Pirate
Old 03-14-2007, 04:39 PM
guinnessdood
guinnessdood's Avatar
My advice on this is always the same. contact Bill Boudreau...www.zfdoc.com Great guy and he knows what he is talking about especially when it comes to anything dealing with the clutch or the ZF-6 tranny
Old 03-14-2007, 04:54 PM
Sgreg
Sgreg's Avatar
If the sound is a very high pitch squealing one, it might also be your pilot bearing. They seem to fail more frequently that throw out bearings.
Old 03-14-2007, 05:51 PM
Goldcylon
Goldcylon's Avatar
Contact Bill. Hes da man!
Old 03-14-2007, 06:55 PM
ittlfly
ittlfly's Avatar
I'll throw my hat into that ring....he is the best.
To Noise from Clutch
Quick Reply: Noise from Clutch
