The Official Chevrolet Corvette ZR-1 Picture Thread
#241
Here are a couple of photos of my 91 #1139 that I bought in May. It has a black interior, both tops and now 44,000 miles on it. I am assuming that it has been chipped because the power key is on from when you start it and the 1-4 shift has been disabled and it has long tube headers, no cats into what looks like a stock LT-1 muffler. The wheels are aftermarket A-Molds that do not have the deep lugs on the back so that is something I will look to change in the future after I work the bugs out.
Jon
Jon
#242
That is one Hot looking vette. Those mods and wheels I am sure set you back a few bucks. I left my 1990 ZR-1 stock as it will be easier to sell down the road, which may be soon as I really like the 2015 C7 Z51 with 8 speed Automatic. Happy motoring.
#244
#245
Received 1,870 Likes
19x10 & 19x11.5 CCW 551's with 275/35/19 & 335/30/19 Nitto NT-05's
"Before" attitude adjustment
"After" lowering done with VB&P adj front spring and 11" rear spring bolts
Momo Tomcat non-airbag wheel w/NRG quick release adapter
#249
1995 ZR-1
Dunn Heads Left and Right
1995 LT5 SPECIFIC TOP END REBUILD TRICKS
A 1995 Top End was rebuilt and best tricks linked here
Post 230 - 1995 LT5 SPECIFIC TOP END REBUILD TRICKS
Post 231 - Clean Up of Valley and Removal Of Crankcase Cover (gasket replaced)
Post 232 - Installation of Rebuilt Starter, New Alternator, and Braided SS Oil Cooler Lines
Post 233 - Battery Disconnect Switch and Installation of Coils
Post 234 - Installation of New Secondary Port Vacuum System hoses
Post 235 - Installation of Reconditioned Injectors with New "O" Rings
Post 236 - Installation/Relocation of Plug Wires and New Spark Plugs
Post 237 - Blocking TB Coolant
Post 238 - Reconditioning and Installation of Plenum with SS Allen Head Bolts
Post 239 - Addition of Billet Aluminum Power Steering, Water Pump, Belt Tensioner Pulleys
Post 240 - Reconditioned 1995 Engine with New Fluids all around including Differential Drain Installed
#251
Hey ZRWON-
I had the same reaction when I stumbled on the ZR1 about 18 months ago. It's a longer story, but for the sake of brevity, I befriended the car's owner of 29 years and convinced him I'd give her the love and attention she deserves. In the deal I have a piece of Corvette history and a good friend to boot.
The car came from the IL/IN area, and I've been able to trace the ownership back to the 3rd in the mid 70's. The car is documented by a partial Order Copy. It's one of 3 known 456 posi ZR1's built in '70.
This is the tightest early (pre C4) corvette I've ever driven, and the solid lifter engine mated to a light weight flywheel lend to a very spirited ride. It drives like the racecar it is; anxious, tight and ready to run!
Here's a pic of the engine bay as found. Dunno why the fan was on backwards though...
Great find....
#253
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
#256
Thanks for your kind offer. I think I have bought most of the parts I need, so I should be Okay. I picked up some when I was in the US last year, and I ordered the brake pads and hoses from the UK.
Are you in Munich on holiday? It is a great city, not too big, and a great atmosphere.
Ken
#257
Hi,
Ken
Ken
Just passing through on my way to Augsburg on business.
#259
Why,thank y'all very much. The fronts are 18-10s and the rears are 19-11 1/2. These have factory BS-OFFSET with 1/2 inch added to inside barrel. The wheels are HRE 560Rs I think,it's been awhile since I got them.
